RTCM Simulcast question
I will be setting up a 2 site UHF simulcast system in the coming months and so far I have only one question to ask. The RTCM manual is a little vague on the GPS part of the setup. Normally, with other types of radio simulcast products (which I am very familiar with several) all you need to properly time the audio is a 1 pps signal from the GPS reference. The RTCM manual makes mention of the NMEA/TSIP data being connected but does not explicitly say if that serial data is needed or if only the 1 pps is needed for simulcast operation. From the other simulcast products I have worked with, you set your bulk delay to a value larger then the delay required for the furthest site and the system will adjust. Does the RTCM version of simulcast work the same way? I just want to be sure because this will determine what type of GPS locked reference oscillator I choose for the project.
Regards,
KC2IRV
-Joe
Virus-free. www.avast.com
Hi Joe,
I can answer part of that for you.
You do need a GPS with NMEA or TSIP. The RTCM needs to know the time so it can time stamp the UDP packets when sending them to the server.
If you go to http://svn.ohnosec.org/viewvc/projects/allstar/voter/?root=svn and look at the VOTER Protocol.pdf and the votersystem.pdf, and look at the protocol parts, you may answer some of your questions.
I know the required NMEA sentences are out there somewhere, but I don’t recall where I saw them.
You can adjust the launch delay on each RTCM, but I do not believe it does any sort of auto adjust.
Lee
Regards,
KC2IRV
-Joe
[email protected]
Lee Woldanski, AScT
VE7FET
While I don’t have any hands on experience simulcasting with RTCMs, I do understand something that is not really documented, only to be found in the depths of the email posts.
If you want reliable simulcast with an acceptable level of overlap warble, you MUST inject a GPS-disciplined 9.6MHz signal to the clock of the RTCMs in leu of their stock internal crystal. Otherwise, the inherent internal clock jitter of the RTCMs will cause CTCSS warble, etc in areas where your transmitters overlap. The 1PPS feed that you normally feed the RTCMS is acceptable for voting, but naturally, a typical crystal-driven clock will slightly drift in between the pulses every second due to inherent jitter, etc, and that ain’t to good for situations like simulcast which demand sample-accurate performance.
If I have misspoken about anything, I apologize and relish the opportunity to be re-educated.
SS
Regards,
KC2IRV
-Joe
[email protected]
KJ6QFS
Sam Skolfield
Hi Joe,
Copying the list so they see your update/questions.
As for votemond/votermon, yes, go with Allmon2. Easier to configure, and many more features at your disposal. :slight_smile:
Lee
On Sat, Jun 4, 2016 at 6:21 PM, Joe Moskalski [email protected] wrote:
Ok, thank you, now I can be sure I get the correct GPS reference unit. Thank you for the link, I had not seen this before.
With this information I will be using this unit for my GPS data, 1pps and 10 Mhz. I have tested one of these it should will work.
http://www.ebay.com/itm/10MHZ-Output-Sine-Wave-GPS-Disciplined-Clock-GPSDO-Antenna-Power-Supply-USA-/281802105734?hash=item419cb6e386:g:to0AAOSwKIpV-hf7
Also does anyone know of someone who has successfully setup a simulcast system with the RTCM’s? I was just wondering if I could touch base with them and possibly avoid any common pitfalls.
Just in case any one was wondering I will be using Kenwood TKR-840 repeaters for this project.
Another question I have is there are references to the votmond java application for monitoring the system but I believe Allmon2 succeeds votmond, is this correct?
On Sat, Jun 4, 2016 at 9:09 PM, Lee Woldanski [email protected] wrote:
Hi Joe,
Lee
Regards,
KC2IRV
-Joe
[email protected]
Lee Woldanski, AScT
VE7FET
Lee Woldanski, AScT
VE7FET
You need both 1 pps and Rx GPS data to the RTCM
Cheers,
Jesse
Regards,
KC2IRV
-Joe
[email protected]
Jesse,
Jim Dixon has articulated this before on the email list. Simulcasting with the RTCMS in overlap areas WON’T WORK PROPERLY without this trivial modification. Obviously this requires usage of IDENTICAL equipment at each site. Here is a pointer to an email of his.
http://ohnosec.org/pipermail/app_rpt-users/2013-November/007704.html
Jim described a possible future RTCM design with convenient provisions for plugging in external 9.6MHz, but this has not happened.
Cheers,
Jesse
Regards,
KC2IRV
-Joe
[email protected]
[email protected]
KJ6QFS
Sam Skolfield
Just throwing this out there… wouldn’t it be possible (trivial?) to configure the PIC (firmware) for 10MHz external clock, and replace the 9.6MHz crystal with 10MHz in from a GPSDO?
Lee
On Sun, Jun 5, 2016 at 1:33 PM, Sam Skolfield [email protected] wrote:
Jesse,
From my understanding as well as many others, simulcasting WON’T work properly in overlap areas unless you replace the RTCM’s internal 9.6MHz crystal with a GPSDO 9.6MHz @3.3 volts p-p. If you expect a cheap 9.6MHz crystal to derive a 1PPS signal and stabilize it between clock pulses down to a level acceptable for accurate syncing of CTCSS generation, free of intrinsic jitter, you are “optimistic” to say the least.
[email protected]
Cheers,
Jesse
Regards,
KC2IRV
-Joe
[email protected]
[email protected]
KJ6QFS
Sam Skolfield
Lee Woldanski, AScT
VE7FET
And that is why I leave software to the smart people… :slight_smile:
Thanks Jim!
Lee
On Sun, Jun 5, 2016 at 11:17 PM, Jim Duuuude [email protected] wrote:
NO
From: [email protected] [email protected] on behalf of Lee Woldanski [email protected]
Sent: Sunday, June 5, 2016 10:22 PM
To: Sam Skolfield
Cc: [email protected]
Subject: Re: [App_rpt-users] RTCM Simulcast question
Lee
Jesse,
his.
[email protected]
Lee Woldanski, AScT
VE7FET
Cheers,
Jesse
Regards,
KC2IRV
-Joe
Virus-free.
www.avast.com
[email protected]
[email protected]
KJ6QFS
Sam Skolfield
Lee Woldanski, AScT
VE7FET
Here’s another link to some more info in an email thread.
http://ohnosec.org/pipermail/app_rpt-users/2015-December/013155.html
Lee
Jesse,
[email protected]
Lee Woldanski, AScT
VE7FET
Cheers,
Jesse
Regards,
KC2IRV
-Joe
[email protected]
[email protected]
KJ6QFS
Sam Skolfield
KJ6QFS
Sam Skolfield
