RTCM question(s)
RTCM question(s)
I occasionally get a connection lost/connect established almost back to back on my RTCM at a remote site. This is on a hardwired IP connection (finally) with pretty low latency and no significant packet loss in the audio on either side.
e.g. here is my response rate from a remote ping to my RTCM
Pinging [64.16….] with 32 bytes of data:
Reply from 64.16….: bytes=32 time=60ms TTL=52
Reply from 64.16….: bytes=32 time=58ms TTL=52
Reply from 64.16….: bytes=32 time=103ms TTL=52
Reply from 64.16….: bytes=32 time=99ms TTL=52
Reply from 64.16….: bytes=32 time=81ms TTL=52
Reply from 64.16….: bytes=32 time=74ms TTL=52
Reply from 64.16….: bytes=32 time=96ms TTL=52
Reply from 64.16….: bytes=32 time=64ms TTL=52
Reply from 64.16….: bytes=32 time=57ms TTL=52
Reply from 64.16….: bytes=32 time=65ms TTL=52
Reply from 64.16….: bytes=32 time=63ms TTL=52
Reply from 64.16….: bytes=32 time=150ms TTL=52
Ping statistics for 64.16….:
Packets: Sent = 37, Received = 37, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 57ms, Maximum = 150ms, Average = 87ms
2 questions. Is there some way to set a time display on the messages on an RTCM when it isn’t connected to a GPS, I can’t tell how long the duration is between the back to back messages because all I get is as follows.
ERROR! Host response timeout
Host Connection Lost (Pri) (24.99.5x.xxx)
Using Primary Voter Host (24.99.5x.xxx)
Host Connection established (Pri) (24.99.5x.xxx)
This is a single RTCM running in simple radio interface mode.
Can you run an RTCM in simple mode and still connect it to a GPS? Will that set it’s time locally?
Is there any way to set a parameter to lengthen the timeout timer in either the voter.conf file or the RTCM configuration? I’m sure we are only talking about a few milliseconds difference is all that’s needed.
Thanks in advance,
Alan
Do you have any way, on the same physical LAN as the RTCM, to put a third device
to monitor packets and use tcpdump/wireshark (depending on your religion… or ahh choice
of OS’s) to see if there is something weird going on? This can easily be accomplished with
the use of an old-fashioned 10base-T hub (not a switch, a HUB).
Jim
To: App_rpt-users@ohnosec.org
Date: Mon, 11 Jun 2012 15:06:19 -0400
Subject: [App_rpt-users] RTCM question(s)
RTCM question(s)
Thanks in advance,
Alan
