RTCM Error Code
Hello, I currently have 4 RTCM’s running for a few years now on a UHF system just fine… I want to start doing the same to a VHF repeater that I have taken over… I created a second port in the voter.conf and attached a new RTCM to that port and it worked for a bout a week now… There was a crew at the site doing work and a power cycle happend on the gear and now the single VHF RTCM is spitting out the following…
12/04/2014 23:59:15.160 Inbound (Eth Rx) packet out of bounds by: -1
All the UHF RTCM’s are connected fine and passing traffic… The server shows the VHF connected and it is receving audio/cor just fine but no TX audio. If i pull the ethernet plug from the vhf it goes into failover mode and local repeats just fine… But with the ethernet plugged in i get no TX audio and the console on the RTCM fills with the above messages…
Fredric Moses - W8FSM - WQOG498
fred@moses.bz
