Hi all,
After much learning and testing, I finally had a configuration that was working using RTCMs as both transmit nodes and voter nodes. I decided to start fresh with clean configs as I was close to rolling this all out at the repeater sites. Somehow, somewhere along the way, I have screwed up something. To simplify narrowing the problem down, I’ve dumped the voter and am just trying to get back to a simple, standalone repeater. The RTCMs are logging into the server OK (Using the latest DIAL distribution), the yellow “Host” light is lit on each RTCM. When I transmit to the RTCM connected repeater, I see the green RX light on the RTCM light (I have removed all CTCSS requirements at this point also), but it’s not transmitting back out (ie, no red TX light, never keys repeater TX). The TX works fine, as when I drop asterisk on the server, the host light extinguishes and I get the “offline” string in CW out on the transmitter. I know I am missing something (something I had working!!). I have a pretty large rpt.conf, but removed all of what I believe(hope) is irrelevant to this question and have listed only the lines I believe should be needed in voter.conf and rpt.conf.
The one thing that is different is that I am no longer seeing voter_chan initialize in the /var/log/asterisk/messages file. I see my node come up in the logfile by app_rpt, but never by chan_voter.
Can someone help me keep the last hair on my head from tearing out and help me understand what I have missed on my new config? I just can’t believe I had all this complicated stuff working, and now can’t get back to the simplest of all of it
Many thanks.
73 James KI0KN
Relevant file sections below: (real password changed to XXXX)
voter.conf:
[general]
port = 667
buflen = 100
password = XXXXX
[5115]
client1 = XXXX,transmit
plfilter = y
rpt.conf:
[5115]
rxchannel = Voter/5115
