RTCM 9.6 MHz OCXO
I felt I needed to let those on this mailing list know my findings with simulcasting with the RTCM units since I have received a great deal of help and information from people on this list.
For the past week I have had a two (2) site simulcast system up and running on UHF using the RTCM units. I have done a great deal of testing and proving on the bench and it is so far working beautifully. The one issue that was made apparent to me early on was that in order for the RTCM’s to be suitable for simulcast, the processor inside it needed to be clocked to a more accurate source. This source is supposed to be the Programmable Clock Generator Module in order to produce a GPS locked 9.6 MHz reference for the processor. Unfortunately this unit is not currently available.
Knowing this, I started to go down the road of possibly designing my own but stumbled upon a cheap, plentiful supply of Symmetricom 9.6 MHz sinewave OCXO’s. I took a chance and ordered a few to experiment with to see if the RTCM would be able to use this in place of the supplied crystal for a clock. I found they did, with that I decided to modify the RTCM with an SMA connector just about the audio adjustment pots and use this OCXO. I trimmed the frequency on the units to match each other and used them to produce the processor clock.
After a week of testing I have found the results in the overlap areas to be exactly as I would expect them on a public safety/commercial simulcast system. While in an overlap region where both transmitters are within 3 dB of one another, to the ear you hear no audio phase wandering. Of course this has only been a week of testing so I wouldn’t call it case closed yet. I will say that if this system remains this way after testing for 6 months to a year than using a 9.6 MHz OXCO is a viable alternative to achieve the needed precision and accuracy needed for the processor clock to make it suitable for simulcast.
If anyone has any questions about my system feel free to contact me. i will more than happy to share everything I have done with anyone.
Thank you to all on the list that contribute.
73’s for now
Joe
KC2IRV
Cc:
---------- Forwarded message ----------
Date: Sep 10, 2016 1:37 AM
Subject: RTCM 9.6 MHz OCXO
To: “app_rpt mailing list” App_rpt-users@ohnosec.org
73’s for now
Joe
KC2IRV
