Node number in question is 1752 (part of a private segment of nodes). Trying to connect from 1727. Stanza below.
[1752] ; Change this to your assigned node number
outstreamcmd=/bin/sh,-c,/usr/bin/lame --preset cbr 16 -r -m m -s 8 --bitwidth 16 - - | /usr/bin/ezstream -qvc /etc/asterisk/ezstream.xml
propagate_dtmf=yes
telemdefault=0
rxchannel = simpleusb/usb ; Rx audio/signalling channel
;rxchannel = radio/usb
;rxchannel = dahdi/pseudo
functions=functions ; Repeater Function Table
phone_functions=functions ; Repeater Function Table
link_functions=functions ; Link Function Table
telemetry=telemetry ; Telemetry descriptions
wait_times=wait-times ; Wait times
context = radio ; Do not Change
callerid = “Repeater” <0000000000> ; Invalid for our network
;idrecording = |ivk7hh/p ; ID, start with |i then your callsign
idrecording =
hangtime=0 ; Repeater Tail. Change to 0 for simplex nodes
althangtime=4000 ; longer Repeater tail. Change to 0 for simplex nodes
totime=300000 ; transmit time-out time (in ms) (optional)
idtime=540000 ; id interval time (in ms) (optional)
politeid=30000 ; time in milliseconds before ID timer
; expires to try and ID in the tail.
; (optional, default is 30000).
idtalkover=|ivk7hh/p ; Talkover ID (optional) default is none
;remotect=ct3 ; remote linked courtesy tone (indicates a remote is in the list of links)
;linkunkeyct=ct8 ; sent when a transmission received over the link unkeys
nounkeyct=0 ; Set to a 1 to eliminate courtesy tones and associated delays.
holdofftelem=0 ; Hold off all telemetry when signal is present on receiver or from connected nodes
;telemdefault=2 ; Hold off all telemetry when signal is present on receiver or from connected nodes
; except when an ID needs to be done and there is a signal coming from a connected node.
duplex=0 ; 0 for repeater gateway (use in conjunction with linktolink)
; 1 for simplex frequency,
; 2 as a repeater (not connected to one)
linktolink=0 ; set to 1 when used as a link full duplex repeater. (no tails,ids etc).
The other node I have has no issues connecting to any other nodes on the network.
Node 1752 won’t connect to anything and gives that above error whenever anything tries to connect to it.
I did not see the [nodes] section of your rpt.conf posting… you do have one ? Need to see that and
entry in extensions.conf
You are running this as a totally private system. Therefore, you do not have the convenience of the built-in security and connection info that a common registry provides. So everything must be explicitly described.
[nodes]
1752 = radio@127.0.0.1:4571/1752,NONE
1727 = radio@rtc.vk7.com.au:4572/1727,NONE
1720 = radio@hh.vk7.com.au:4570/1720,NONE
50423 = radio@vk6gc.hopto.org:4569/50423,NONE
54048 = radio@vk6gc.hopto.org:4569/54048,NONE
;Include your local nodes here you do not want to be on the Nevarc system. Use ID’s between 1000 and 1099
Extensions.conf
[general]
static=yes ; These two lines prevent the command-line interface
writeprotect=yes ; from overwriting the config file. Leave them here.
