RPI2 DIAL
Any suggestions on places to look if my node is resetting. Two things are happening. I run two nodes on one server. One of those nodes is permanently connected to the other. Then the other node is permanently to a remote hub.
So sometimes my nodes briefly disconnect and reconnect. When I look in allmon2 I see that everything reconnected on their own leading me to believe the network briefly dropped.
The second scenario is my node isn’t connected leading me to believe a reboot happened.
I realize I can run a macro to automatically connect when it powers up. What I’d like to know is something happening with the power at the site or is my RPI2 having a problem. The site owner says no this happening. Although he has no indication is he is losing power or network.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086
You can check /var/log/syslog for reboots.
Also /var/log/asterisk/messages
Up the verbosity
Steve
On 12/8/2015 9:27 AM, Robert Newberry
briefly dropped.
    The second scenario is my node isn't connected
N1XBM
    Apparare Scientor
    Paratus Communicare
Log in to the pi2 and do an uptime. That will tell you how long it has been powered up.
Sent from my iPhone
N1XBM
Apparare Scientor
Paratus Communicare
I replied directly to Corey and not to the list. So I’ll check top for uptime and I’ll monitor that. I’ll also monitor the logs. Everything looks ok. The only thing I see that may be suspicious is.
Transfer to device 4 endpoint 0x2 frame 1141 failed - FIQ reported NYET. Data may have been lost.
N1XBM
Apparare Scientor
Paratus Communicare
OK I just had this problem… One of my antennas was 12" a way from the RPi and when the radio (5 watts) keyed up the RPi rebooted. I couldn’t figure why it was rebooting. I moved the antenna and all is well.
David
KE6UPI
N1XBM
Apparare Scientor
Paratus Communicare
