Hi All, trying to set up a new RPI node. Using latest rpi Dial release. But need the default root password. Doesn't seem to be listed on the Allstar wiki.
the one for Repeater is listed but not root.
Anyone point me in the right direction?
Cant proceed with configuring my node until I have rot password.
Used to be debian but I guess it was changed since the last release.
You have to set one; “sudo” into root, then generate a new root password.
Bob
K6ECM
Sent from iPad
Also, if you want to ssh isn’t root, edit /etc/ssh/ssh_config
Change: #PermitRootLogin prohibit-password
To:
PermitRootLogin yes
If you want to change the host name from repeater, edit /etc/hostname
Bob
K6ECM
Bob
K6ECM
Sent from iPad
Bob
K6ECM
Sent from iPad
On Sep 3, 2018, at 9:58 AM, REDBUTTON_CTRL jrorke@cogeco.ca wrote:
Hi All, trying to set up a new RPI node. Using latest rpi Dial release. But need the default root password. Doesn’t seem to be listed on the Allstar wiki.
Hello all. I did the instructions using sudo asl-menu a few times over.
It brought me to would you like to change the root password.
I followed the instructions a few times but no joy.
It would not change the root password.
Also, I kept trying to set the interface to static.
I followed the menu, made the changes, used the save command
and still no change.
FYI, I am doing my attempts using SSH via the ethernet port.
Is this something that only works via local?
Tnx, Mark WB2ERS
Yes, local or under sudo in root. You need to edit /etc/ssh/sshd_config. Change “PermitRootLogin yes” and you can edit your port number as well by removing the #.
Tnx, Mark WB2ERS
