Reverse Autopatch radio PTT
I finally got my main PBX peered to my app_rpt box (long story) and I set up normal phone control mode to have full functionality. With simple phone control, I can key/unkey the transmitter with * and # respectively.
How do I accomplish that in normal phone control mode? Also, if I connect to an echolink or allstar node from my phone, how does audio (if it can be) get sent to the network?
For example, say I connect to my node via phone and I want to connect to Allstar node 2000. Can I send audio from my phone? I am finding it very useful to monitor things, but the ability to transmit audio to the network would be rather neat…
Is this possible or is this beyond the scope of design?
tnx and 73
Stephen
K1LNX
Stephen Brown - ARS K1LNX
Johnson City, TN EM86
http://www.k1lnx.net
google voice: 423-665-9367
Hi Stephen,
I'm using normal mode of reverse autopatch and by default, you should
be able to key up with *98 and un-key with #. Of course you can change
those to something else and the best way to do that so you don't
affect regular users used to the existing mappings is to edit rpt.conf
and dup the entire [funtions] stanza creating a second one called
[p_functions] and then change the line earlier in the file that maps
phone_funtions from funtions to p_functions. If you look at the file
you'll see what I mean.
Cheers,
Keith
KF7DRV
Node 2541
would be rather neat.....
tnx and 73
Stephen
K1LNX
Sent from my mobile device
