Remote base using FT-817ND
Hello group,
I need help with a remote base setup using a Yaesu FT-817ND. I just setup a second node on my ACID box using an URIx for the remote base. Everything is working fine with tx audio, rx audio, COR and PTT. I am having issue with the CAT control. I connect from my UHF repeater node on the box using *3701 and try to issue remote base commands and the radio will not respond to CAT commands.
Here is what I have in the rpt.conf
[701]
rxchannel = Radio/usb701 ; Rx audio/signaling channel
remote = ft897 ; Radio Type
functions = functions701 ; Function list from link
phone_functions = functions701 ; Function list from phone
ioport = /dev/ttyUSB0 ; Serial port for control
iospeed = 4800
dusbabek = yes
authlevel = 0 ; Authorization level
;; authlevel = 0 : Anyone can use it
;; authlevel = 1 : Requires log in, Waits for Tx key to ask for it
;; authlevel = 2 : Requires log in, asks for it automously
;mars = 0 ; set=1 for IC-706 w/MARS mods (optional)
remote_inact_timeout=1800 ; Inactivity timer for remote base nodes only (set to 0 to disable).
remote_timeout=5400 ; Session time out for remote base. (set to 0 to disable)
;remote_timeout=120 ; Session time out for remote base. (set to 0 to disable)
;remote_timeout_warning=30
why did you set dusbabek to yes?
Leave Lee out of this!!!
Jim
ยทยทยท
To: app_rpt-users@ohnosec.org
Date: Fri, 11 Jan 2013 19:57:44 -0600
Subject: [App_rpt-users] Remote base using FT-817ND
Hello group,
[701]
iospeed = 4800
dusbabek = yes
