I have an old system that has been running the ACID distro for several years and it has developed some hardware problems so I am in the process of replacing it with a Pi3. I had 2 nodes running on the system. The first node was connected to a repeater controller and the 2nd node is a 2M remote base, specifically a Kenwood Tm-271A. I have the first node working just fine but the remote base is not working at all. The audio and transmit are OK but the remote base commands are not working. I also have authlevel = 2 and it never prompts me to log in. Does the PI distro support remote bases? Out of desperation, I even took my config files from the ACID machine and dropped into the Pi with no success. Either it doesn’t support it now or I have missed something.
Thanks in advance
Jamey - WR4JW
