I connected my SHARI node from QTH to a node / hub, every 1 or 2 min my HT kept telling “Remote already in this mode” . I do not know what was that all about since this is only node / hub that is kept doing it. I connected to other node / hub, I do not hear this message.
Likely the other end if you are not commanding it to connect in RX or TX when it already is.
your commands are not likely the same as mine but find it in your rpt.conf file and turn
Foreign Link Local Output Path Disable
936 = cop,36 ; Foreign Link Local Output Path Enable
937 = cop,37 ; Foreign Link Local Output Path Disable
938 = cop,38 ; Foreign Link Local Output Path Follows Local Telemetry
939 = cop,39 ; Foreign Link Local Output Path on Demand
At any rate, I have a SHARI PiHAT UHF Allstarlink node at home QTH. I logged in to Supermon typed in my node / hub ID and clicked “Connect” and off I went walk around the house using analog handheld.
Mike, I removed ";" in the front of 937 = cop, 37 and reload asterisk. I tried to send *937 from Supermon DTMF, it does not seem to do anything. I tried to send *937 and *937# from my handheld I see ASL see all my DTMF characters but she kept on saying "Remote already in this mode". I must have skipped some step or not doing it correctly.
certain conditions. Type 'core show license' for details.
Connected to Asterisk GIT 6914538 currently running on repeater-u (pid = 832)
Verbosity is at least 3
-- Event on node 547612 doing rpt command cop,62,GPIO4:1 for condition c|t|RPT_RXKEYED
[Nov 1 16:38:45] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char *
[Nov 1 16:38:45] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 9
[Nov 1 16:38:46] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 3
[Nov 1 16:38:47] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 7
-- Event on node 547612 doing rpt command cop,62,GPIO4:0 for condition c|f|RPT_RXKEYED
[Nov 1 16:38:57] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char *
[Nov 1 16:38:58] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 9
[Nov 1 16:38:58] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 3
[Nov 1 16:38:59] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char 7
[Nov 1 16:39:00] NOTICE[855]: chan_simpleusb.c:2910 simpleusb_read: Got DTMF char #
-- <DAHDI/pseudo-1805489998> Playing 'rpt/remote_already' (language 'en')
-- Hungup 'DAHDI/pseudo-1805489998'
== Refreshing DNS lookups.
[Nov 1 16:39:15] NOTICE[834]: dnsmgr.c:178 dnsmgr_refresh: host 'register.allstarlink.org' changed from 162.248.92.131 to 34.105.111.212
-- <DAHDI/pseudo-903809827> Playing 'rpt/remote_already' (language 'en')
-- Hungup 'DAHDI/pseudo-903809827'
-- <DAHDI/pseudo-755831621> Playing 'rpt/remote_already' (language 'en')
-- Hungup 'DAHDI/pseudo-755831621'
-- <DAHDI/pseudo-82397634> Playing 'rpt/remote_already' (language 'en')
-- Hungup 'DAHDI/pseudo-82397634'
-- <DAHDI/pseudo-1757178950> Playing 'rpt/remote_already' (language 'en')
-- Hungup 'DAHDI/pseudo-1757178950'
Only a couple of ideas and notes.
I mentioned those commands I used are likely something that I modified from a very old default install and could perhaps clash with the current default command setup which I do not have a copy of to tell you any better. I have been using the same modified file for more than 10 years.
You will come to understand more particulars about commands with experience.
Perhaps for a test, use 640 and 641 to turn this off and on as there should not be anything in conflict in the 60’s except for 60 61 on the phone patch by default.
641 = cop,36
640 = cop,37 ; Foreign Link Local Output Path Disable
If it works, then you can find a nest for a proper command entry, Or we will have to find the standard for it.
So you did remove the ‘;’ at the beginning of the line?
I can not speak to anything supermon. NOR with hamvoip if you are using it.
There are differences and I am not aware of what all they are, if any.
