Reliability / Network Stability
Over the course of the last six months or so, I have noticed there have
been some issues with allstarlink.
Either the allstarlink website doesn't work, connections are radanomly
dropped on known high-reliability networks and connected equipment.
All without apparent cause.
Again today, for no apparent reason, all links on several systems in
this area were dropped, and were not able to connect to anyone. Some of
our nodes have "direct access" to other nodes specified in the rpt.conf,
and those connections worked fine.
When a node cannot connect to node 2000, or some other random one, there
is an issue.
All nodes in this area have different ISPs, so it rules out the
possibility of ISP issue.
Other folks I have talked to across the country have stated they have
noticed similar issues.
Has anyone noticed this, and not said anything, or what is going on?
~Benjamin, KB9LFZ
There have been the occasional issue of nodes not being able to connect which has been down to the database that is downloaded to your node from allstarlink not always being populated with any data. (It has only happened to people who have restarted their node for some reason) This has happened to a few people I know on a small number of occasions. There has been a little chatter about it in related forums but to be honest this is an Amateur System provided to us freely through the kind generosity of a small number of radio hams. I don’t expect it to be a military grade 100% bomb proof system and expect there to be the odd bump along the way!
On another note, connections being dropped are not anything to do with allstarlink it can only be an issue with the individual nodes themselves, internet connectivity etc. All allstarlink is involved with is providing the database telling your node the IP address of all the other nodes in the system. Once you are connected it’s out of there hands.
Thanks again to Steve and all the guys behind the scene…
Cheers
Steve M0HOY
is an issue.
~Benjamin, KB9LFZ
Have you tried to diagnose the problem?
Sense you wrote the nodes in rpt.conf you wouldn’t need a list from the master servers. So my question is, does the other nodes have your node info in their rpt.conf file? Have you tried mtr to test your nodes network? When you try to connect what does the logs or command line output say?
Like to help,
David
KE6UPI
Cheers
Steve M0HOY
Either the allstarlink website doesn’t work, connections are radanomly
our nodes have “direct access” to other nodes specified in the rpt.conf,
is an issue.
~Benjamin, KB9LFZ
Thanks, David
“Laws that forbid the carrying of arms…disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one.”
Thomas Jefferson
When and where?
Allstarlink.org is and has been online and stable for some time.
Docs.allstarlink.org had a network outage recently due to a dead switch. It
was rectified about 5-6 hours later by our network vendor.
Again, when and where? Connections from node to node are direct, the only
thing ASL does is build a database and push that to the nodes every 10 mins or
so.
If your nodes are listed as online, but they cannot talk, there is a network
issue unrelated to ASL.
is an issue.
This sort of "error" report is lacking. You would need to give the errors,
dates/times, source node IP and AS path if you can provide that.
No, it makes it less likely, but it in no way rules it out. Are you doing NAT
or is each node on it's own IP?
This is nothing but scuttlebutt without evidence.
In the last 6 months ASL has lost Jim Dixon, formally incorporated as a
non-profit organization and been forced to document a number of things which
Jim had in his head.
"The death of God left the angels in a strange position."
We had to identify the ASL infrastructure, which was spread out over a number
of different locations. We've done this and have access to everything, and
backups in case anything fails. We've assembled an infrastructure team and
have an architecture we're building into (docker). Over the next few months
we're going to move servers one by one into this environment.
The mailing lists have been moved to a high performance server with real spam
filtering. Nagios is watching everything and we know in 5-10 minutes when
there is an outage of a service.
This is a huge undertaking.
Tim's working on a new website, and Steve's been running everything else
including development. Oh, and all the source code is on github now too.
If there's network issues we _want_ to know about them, but it must be in a
detailed manner. I've responded to people on reddit and said to post details
over on this list. Without detailed logs and reports we cannot do anything to
confirm them.
73's
On 6/26/17 9:10 PM, Benjamin Naber wrote:
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
Sounds good Bryan! Also special shout out to the rest of the team as well… I think i might have an idea what maybe going on in regards to your question Benjamin… I have recently noticed heavier than normal latency on the iax ports I am not sure if service providers are doing some funny business with 4569 or what… But what i recommend is if your having connectivity issues download mtr on to your allstarlink node… You can install it by typing apt-get install mtr then use this command as an example mtr -rwc 100 ip-p-host-Address
example command would be:
mtr -rwc 100 lorentedford.com
Now this will show you percentages of packet loss for each hop this is generally a good place to start in troubleshooting if your having issues…
Providing the output of the above can be very useful and assist others in seeing what type of network congestion is going on where around the country… In the future some of us might have to look into consistent VPN services between major hubs to maintain stable connectivity and routing… Examples being multiple hub systems where you have geographically located allstarlink hubs around the world…
Just a thought
When and where?
so.
is an issue.
This sort of “error” report is lacking. You would need to give the errors,
or is each node on it’s own IP?
“The death of God left the angels in a strange position.”
of different locations. We’ve done this and have access to everything, and
backups in case anything fails. We’ve assembled an infrastructure team and
have an architecture we’re building into (docker). Over the next few months
we’re going to move servers one by one into this environment.
Tim’s working on a new website, and Steve’s been running everything else
If there’s network issues we want to know about them, but it must be in a
detailed manner. I’ve responded to people on reddit and said to post details
confirm them.
73’s
Bryan Fields
Loren Tedford (KC9ZHV)
Phone:
Fax:
Email: lorentedford@gmail.com
Email: KC9ZHV@KC9ZHV.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://forum.kc9zhv.com
http://hub.kc9zhv.com
http://Ltcraft.net
http://voipham.com
Sorry for the double email forgot to add some things…
Just a thought
On Tue, Jun 27, 2017 at 11:24 AM, Loren Tedford lorentedford@gmail.com wrote:
Just a thought
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
When and where?
so.
is an issue.
confirm them.
73’s
Bryan Fields
Just a comment about using mtr or other tools that attempt to show packet
loss to various ISP core or edge routers--this really does NOT give an
accurate picture, in many cases, particularly for latency....The job of
these routers is to forward traffic, not respond to pings.
...And, I am an ISP with core and edge routers.
73, David KB4FXC
On Tue, 27 Jun 2017, Loren Tedford wrote:
Sounds good Bryan! Also special shout out to the rest of the team as well..
question Benjamin.. I have recently noticed heavier than normal latency on
business with 4569 or what.. But what i recommend is if your having
connectivity issues download mtr on to your allstarlink node.. You can
generally a good place to start in troubleshooting if your having issues..
country.. In the future some of us might have to look into consistent VPN
services between major hubs to maintain stable connectivity and routing..
allstarlink hubs around the world..
Just a thought
Phone:
Fax:
http://Ltcraft.net <http://ltcraft.net/&gt;
http://voipham.com
On Tue, Jun 27, 2017 at 10:57 AM, Bryan Fields <Bryan@bryanfields.net> > wrote:
> When and where?
> It
> mins or
> so.
> network
> > is an issue.
> NAT
> which
> number
> months
> spam
> details
> anything to
> confirm them.
> 73's
> Bryan Fields
> App_rpt-users mailing list
> App_rpt-users@lists.allstarlink.org
> options button"
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a message to
> the list detailing the problem.
That’s great David however most people don’t want to spend the time and energy into getting a pfsense box and fighting with their provider unless they can get reasonable idea of what is going on the network side of things… I agree ping’s packet loss isn’t everything but I have found that mtr is still good basic for individuals looking to trouble shooting network issues…
I can’t help what providers block out on their end of the network… However ping times and percentage of packet loss is a good start just to get an idea…
I am sorry i didn’t add nothing is perfect…
So in curiosity side in the linux world what tool would you use to diagnose your connections?? This is assuming you already use ping commands and netstat commands etc…
loss to various ISP core or edge routers–this really does NOT give an
accurate picture, in many cases, particularly for latency…The job of
…And, I am an ISP with core and edge routers.
73, David KB4FXC
Just a thought
Phone:
Fax:
http://Ltcraft.net <http://ltcraft.net/>
http://voipham.com
When and where?
It
mins or
so.
network
is an issue.
NAT
which
number
months
spam
details
anything to
confirm them.
73’s
Bryan Fields
options button"
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
Most core and edge routers (most notably Cisco devices) provide priority to regular packet forwarding. An ICMP reply is given much lower priority. As a result, you can’t rely on the ICMP information provided by these devices under test as being accurate. David is absolutely correct with his statements. I’ve personally seen Cisco routers indicate ~10% packet loss while doing a ping test, but with forwarded packets being unaffected at 0% loss.
On Tue, Jun 27, 2017 at 11:50 AM, Loren Tedford lorentedford@gmail.com wrote:
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
73, David KB4FXC
Just a thought
Phone:
Fax:
http://voipham.com
When and where?
It
mins or
so.
network
is an issue.
NAT
which
number
months
spam
details
anything to
confirm them.
73’s
Bryan Fields
options button"
Andrew Sylthe
KC9ONA
Loren,
I think you missed David's point. He's saying that ICMP loss to core
routers is not an accurate assessment of their packet forwarding
ability. These routers have dedicated hardware to forward packets and
can do so at line rate. However, when a ping comes in addressed to
them, this does not get handled by the dedicated packet forwarding
chip. It must be sent to the CPU for processing. If the CPU has some
free time, it will parse the ICMP packet, find the echo request, and
send an echo reply. If the CPU is busy, it'll just ignore the packet.
Pings are the lowest priority in a router like this.
To test for packet loss, use an end-to-end tool on the same protocol
as your application. In this case, test for UDP loss and jitter. You
can do that with a tool like iperf:
Tom KD7LXL
On Tue, Jun 27, 2017 at 9:50 AM, Loren Tedford <lorentedford@gmail.com> wrote:
That's great David however most people don't want to spend the time and
things.. I agree ping's packet loss isn't everything but I have found that
issues..
I can't help what providers block out on their end of the network.. However
idea..
I am sorry i didn't add nothing is perfect..
netstat commands etc..
Tom can you explain a bit more on iperf? How to install and run from command line and possibly from windows?
issues…
idea…
Loren,
I think you missed David’s point. He’s saying that ICMP loss to core
send an echo reply. If the CPU is busy, it’ll just ignore the packet.
https://iperf.fr/
Tom KD7LXL
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
Sorry, I'm not a Windows user and don't know how. Besides, you'll want
to test this between two nodes. Testing on Windows would be
superfluous.
On DIAL you can install it with:
sudo apt update && sudo apt install -y iperf3
Tom KD7LXL
On Tue, Jun 27, 2017 at 10:22 AM, Loren Tedford <lorentedford@gmail.com> wrote:
Who is your service provider?
Lu Vencl
is an issue.
~Benjamin, KB9LFZ
Ok i am playing around with iperf could some one hold my hand and explain to me exactly what i am looking for in issues with my voip traffic since mtr is not a viable solution to figuring this out??
Here is Server Side Stuff and Information
root@vhf:~# sh speedtest.sh
Retrieving speedtest.net configuration…
Testing from OVH (158.69.235.237)…
Retrieving speedtest.net server list…
Selecting best server based on ping…
Hosted by Fibrenoire Internet (Montreal, QC) [1.26 km]: 2.094 ms
Testing download speed…
Download: 650.05 Mbit/s
Testing upload speed…
Upload: 795.92 Mbit/s
root@vhf:~#
root@vhf:~# iperf -s -u
Lu Vencl
is an issue.
~Benjamin, KB9LFZ
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
WoW, who took over knology in this area.
No issues, have been reported, although trying to actually talk to
someone who works in their local NOC, is like pulling teeth.
Their has been some issues with DNS, have no lead at to why, so I
replaced the URL strings with IPs in the iax.conf.
~Benjamin, KB9LFZ
Lu Vencl
> is an issue.
> ~Benjamin, KB9LFZ
> You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
Which area is that? What is your IP?
Typical of any MSO. You need know the right contacts with clue.
You may want to use an alternate DNS server.
On 6/27/17 4:20 PM, Benjamin Naber wrote:
Bryan Fields
8.8.8.8 and 8.8.4.4 are google’s high availability/DR’d DNS servers.
Bryan
Bryan Fields
I never rely on my ISP for DNS lookups. I find that they are good at providing me transit, but are terrible for keeping servers and services running.
I am lucky enough to have a pair of DNS servers scattered about the US, but if I didnt have them, I would rely on google (8.8.8.8)
Jim, K6JWN
Sent from my iPhone
~Benjamin, KB9LFZ
Lu Vencl
is an issue.
~Benjamin, KB9LFZ
Still no response on this.
The Director of Network Architecture at WOW! is a personal friend and fellow
ham. This listserv/dns server is in a WOW business facility.
I'd have gotten to the bottom of this had he provided a response.
73's
-------- Forwarded Message --------
Subject: Re: [App_rpt-users] Reliability / Network Stability
Date: Tue, 27 Jun 2017 16:42:55 -0400
Reply-To: Users of Asterisk app_rpt <app_rpt-users@lists.allstarlink.org>
Bryan Fields
