To: app_rpt-users@qrvc.com
Date: Tue, 25 Aug 2009 09:34:23 -0700
Subject: Re: [App_rpt-users] Registration Refused
… and this is my nodes stanza
[nodes]
2528 = radio@127.0.0.1/2528,NONE ; VHF
2529 = radio@127.0.0.1/2529,NONE ; UHF
Tim
:wq
On Aug 25, 2009, at 8:39 AM, Tim Sawyer wrote:
Thanks Jon,
I removed the second statpost_program and restarted asterisk but it
still is not reporting. Here are my two node stanzas:
[2528] ; Change this to your assigned node number
rxchannel = Radio/usb ; Rx audio/signalling channel
controlstates=controlstates ; system control state list
scheduler=schedule; ; scheduler entries
functions=functions ; Repeater Function Table
phone_functions=functions ; Repeater Function Table
link_functions=link-functions ; Link Function Table
telemetry=telemetry ; Telemetry descriptions
wait_times=wait-times ; Wait times
context = radio ; dialing context for phone
callerid = “WD6AWP Repeater” <7140000000> ; callerid for phone calls
; idrecording = |iwd6awp/r ; Main ID message
idrecording = /etc/asterisk/wd6awp-r ; Main ID message
accountcode=RADIO ; account code (optional)
hangtime=1000 ; squelch tail hang time (in ms) (optional)
althangtime=5000 ; longer squelch tail
totime=1200000 ; transmit time-out time (in ms) (optional)
idtime=540000 ; id interval time (in ms) (optional)
; The default values for hangtime, time-out time, and id interval time
are
; 5 seconds (5000 ms), 3 minutes (180000 ms), and 5 minutes (300000 ms)
; respectively
politeid=30000 ; time in milliseconds before ID timer
; expires to try and ID in the tail.
; (optional, default is 30000).
idtalkover=|iwd6awp/r ; Talkover ID (optional) default is none
unlinkedct=ct9 ; unlinked courtesy tone (optional) default is none
remotect=ct3
linkunkeyct=ct1
statpost_program=/usr/bin/wget,-q,–output-document=/dev/null
statpost_url=http://stats.allstarlink.org/uhandler.php
erxgain=-3.0 ; defaults to -3.0 db
etxgain=3.0 ; defaults to 3.0 db.
irxgain=-3.0 ; defaults to -10.0 db
itxgain=3.0 ; defaults to 10.0 db.
macro = mymacros
[2529] ; Change this to your assigned node number
rxchannel = Radio/usb1 ; Rx audio/signalling channel
are
; respectively
remotect=ct3
linkunkeyct=ct1
; statpost_program=/usr/bin/wget,-q,–output-document=/dev/null
macro = mymacros
Tim
:wq
On Aug 25, 2009, at 7:15 AM, Jon Rorke wrote:
If you are doing a 2 node system, then you also need to set up the
rpt.conf file to report both nodes separately.
Your IAX file is most likely ok.
In you rpt conf file you need to have the reporting lines in each node
stanza.
eg:
[first node]
(node 1 config stuff)
Add the stat post lines as per normal:
statpost_program=/usr/bin/wget,-q,–timeout=15,–tries=1,–output-
document=/dev/null
; get Allstar updates for node look up
statpost_url=http://stats.allstarlink.org/uhandler.php ; Report this
node to Allstar stats page
And at the end of the second node just add this line:
[second node]
(node 2 config stuff)
Note that the line for getting node updates must not be here. Only the
line that reports to the Allstar server.
Hope this helps.
Jon VA3RQ
Tim Sawyer wrote:
I’m setting up a second node for the first time and it won’t register.
/etc/asterisk/iax.conf:
[general]
register=A2528:0xxxxx@register.allstarlink.org
register=A2529:0xxxxx@register.allstarlink.org
/var/log/astersik/messages:
[Aug 25 05:41:57] NOTICE[16131] chan_iax2.c: Registration of ‘A2529’
rejected: ‘Registration Refused’ from: ‘xxx.xxx.xxx.xxx’
[Aug 25 05:42:47] NOTICE[16129] chan_iax2.c: Registration of ‘A2529’
[Aug 25 05:43:37] NOTICE[16128] chan_iax2.c: Registration of ‘A2529’
I’ve confirmed the new password and tripple check my conf files. The
new node is otherwise working. Any ideas?
Tim, WD6AWP
:wq
App_rpt-users@qrvc.com
