I have checked the password several times. I did change the password last night and never registered with the password assigned by Allstar, only attempted with the new password.
The node works locally otherwise. Any help you can provide would be appreciated!
As a test login to your web portal account and change your node password to 6 characters (numbers and letters, no special characters) something simple.
Change your registration password line on your node as well, reboot the node and see if the works.
Let us know.
Marshall - ke6pcv
From: John via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org] Sent: Thursday, November 12, 2020 12:01 PM To:ke6pcv@cal-net.org Subject: [AllStarLink Discussion Groups] [App_rpt-users] Registration Refused for New Node
when entering numeric information in the .conf files, I’ve found that sometimes using the numeric keypad will display the right number, but it will be something different in the file for some reason. I use the top row of keys on the keyboard when it comes to things like this and have never had a problem (I cause others, so, trying to minimize the number I have to work through…)
