After a few iterations of this, I decided that the next time this happens, that I would just blow away to rule and rebuild it and see what happens. Sure enough that was the key to fix the issue. Keep in mind, it takes a little while sometimes for all the other nodes to see that you registered by the update to the ip list ,but in my case the problem seems to be with the router. It is a two wire DSL router and one day I will replace it with one that someone could recommend. But for whatever it is worth, I am able to log into the modem remotely and issue a restart. I have found that sometimes it takes 2 to 3 restarts to the modem/router and the problem is resolved. I don't understand why this continues to be a problem but it could possibly be similar in your case.
Lu Vencl
[email protected]
Hi,
I think you're hitting a security feature of the Registration System.
When running wget (or the node info collection scripts, like:
rc.updatenodelist), you must use the same source IP address as
used during the Asterisk registration requests sent from Asterisk when it
is running. And, your node must be properly registered to retrieve the
node list.
So, is the source IP address of the AllStar/Asterisk server on the
44.0.0.0/8 network? And, if so, when running wget, do you use the same
source IP address as Asterisk? If not, these addresses must be the same.
Merry Christmas and Happy Holidays!!
73, David KB4FXC
On Wed, 23 Dec 2015, Bobby Lacey wrote:
Hello!
Every few months, we run into a problem where our nodes will de-register
with register.allstarlink.org and just set there before timing out and
retrying. It never does register until it just magically starts working
again often many days later.
I haven't really had time to troubleshooted it before, but since I'm home
from work for a few days, I'm trying to trace down the problem.
Something interesting I've found: These nodes are sitting on my 44Net (
44.0.0.0/8) address space and get the following when I try to wget nodes.pl:
[root@146-760 ~]# wget http://nodes1.allstarlink.org/cgi-bin/nodes.pl
--2015-12-23 11:36:23-- http://nodes1.allstarlink.org/cgi-bin/nodes.pl
Resolving nodes1.allstarlink.org (nodes1.allstarlink.org)... 96.36.57.202
Connecting to nodes1.allstarlink.org
(nodes1.allstarlink.org)|96.36.57.202|:80...
connected.
HTTP request sent, awaiting response... 403
2015-12-23 11:36:23 ERROR 403: (no description).
[root@146-760 ~]# wget http://nodes2.allstarlink.org/cgi-bin/nodes.pl
--2015-12-23 11:36:57-- http://nodes2.allstarlink.org/cgi-bin/nodes.pl
Resolving nodes2.allstarlink.org (nodes2.allstarlink.org)... 209.159.155.200
Connecting to nodes2.allstarlink.org
(nodes2.allstarlink.org)|209.159.155.200|:80...
connected.
HTTP request sent, awaiting response... 403 Forbidden
2015-12-23 11:36:57 ERROR 403: Forbidden.
[root@146-760 ~]# wget http://nodes3.allstarlink.org/cgi-bin/nodes.pl
--2015-12-23 11:37:28-- http://nodes3.allstarlink.org/cgi-bin/nodes.pl
Resolving nodes3.allstarlink.org (nodes3.allstarlink.org)... 65.110.110.172
Connecting to nodes3.allstarlink.org
(nodes3.allstarlink.org)|65.110.110.172|:80...
connected.
2015-12-23 11:37:28 ERROR 403: (no description).
When I try from my ISP's public IP (non 44Net), it works fine. This is just
an observation and I'm not sure if it actually is the problem.
Anyone have any ideas?
Tnx and 73
Bobby
KF4GTA
[email protected]
