Registration for 49961 failing
Good morning,
I’m helping out Ruben KK6IMI with his node 49961. Did a clean install for him because his node was not registering:
node49961CLI> iax2 show registry
44.72.21.13:4569 Y 49961 60 Registered
node49961
CLI>
Even on a clean install it refuses to register. Could I trouble you to take a look at his record and see if there’s anything amiss ?
Many thanks,
Gerry.
W6WNG
That is indicating the node is registered.
What indications are you seeing that indicates the node is not registered?
I think the “perceived” is blank - and it was not green on the web portal.
Thanks Tim - we found it - the node password was wrong.
I should have asked that question first.
Thanks for looking into it.
Best,
Gerry
W6WNG
