Installed all the setup. Have a node that will not connect to any other node. Passwords are correct and when I list nodes, its shown there as active. Help desk said its not registered, How do I do that? I though I did it already.
The registration takes place and is configured in iax.conf in a line that looks similar to:
register=292xx:pasword@register.allstarlink.org
in the general section of the file
registar=user(node#):passw@register.allstarlink.org
The password can be found in the user portal for the node in question. Each node will have it’s own registration on a line of it’s own in the file.
It may take 10 minutes for the registration data to propagate to nodes for connection acceptance after the data is set and you restart the system.
If you still need help, please tell us the node number.
