regenerate dtmf touchtones
Is it possible to send or regenerate a dtmf tone across a link without being muted. I want to be able to control a linker II controller over the link if possible. I have tried the ilink dtmf commands set up in macros with no success. They don’t make it through to the controller I am trying to control on the other end.
Neal
NG8Y
If “the controller” on the other end is Asterisk, then you can use the “remote command” feature
http://ohnosec.org/drupal/node/21
You do *4 and the remote node number as the “command”.
After that, the next command you send to your local node gets passed through to the remote node - and executed there.
GL
Ken
KE2N
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Neal Garbenis
Sent: Friday, April 01, 2011 7:08 PM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] regenerate dtmf touchtones
Neal
NG8Y
GL
Ken
KE2N
Neal
NG8Y
Neal
NG8Y
Ken
Thanks for the help I got it to work
Add to rpt.conf to the box you want tones to pass from
propagate_dtmf = yes ; DTMF sent to system from link gets
; repeated onto main system output(optional)
Then use the *4 remote command for that node. Any dtmf tone will now pass through the link. This works great for my application it allows me to control a non asterisk controller from the other end.
Neal
Sent: Friday, April 01, 2011 5:25 PM
To: ‘Neal Garbenis’; app_rpt-users@ohnosec.org
Subject: RE: [App_rpt-users] regenerate dtmf touchtones
GL
Ken
KE2N
Neal
NG8Y
I have it semi working. It sounds like the dtmf volume level is to high and the controller is not recognizing all the tones. Is there a way to adjust the DTMF level.
Brian
KB3ORS
Sent: Saturday, April 02, 2011 10:11 AM
To: ‘Ken’ ; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] regenerate dtmf touchtones
Ken
Neal
Subject:
GL
Ken
KE2N
Neal
NG8Y
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1209 / Virus Database: 1500/3546 - Release Date: 04/02/11
