Receive only ASL3 ISSUE
I have nodes showing up Receive only??? I run this system and have access to almost every node on this system. WE DO NET HAVE THEM SET THIS WAY.
Help
You know me. I don’t come here with nonsense.
N3DMC
Dave
https://cloud.n3dmc.org/supermon/link.php?nodes=645310,503600,559820,559822,1000,1776
I disconnect South Coast Reflector. Our side cleared up but its still showing the problem on SCR dashboard. Chuck I sent you a message with SCR page. When I get back on the computer I will post it here.
Just looked and SCR looks OK. Am I looking for systems coming up in Monitor mode?
Now its back to normal. Just wild. I question if it starts with a larger group like before 5PM thing. The right side was slowly going to receive only on more and more. I will need to check logs too.
Allstarlink programmers working hard making stuff better. Had to let the dust settle and everything is more stable again. Thank you all for the hard work and dedication.
Problem has returned. I need assistance
I can see it. The machines making outbound connects are where it's happening.
Are these really Receive Only connections, and not just indicated as such?
Then, nodes all revert to Transceive.
The problem looks like it is at the SCR hub - connections to it revert to Monitor/Receive immediately.
I wonder if it is hitting a limit of some sort, then does this behavior...
Interesting. I’ve been working on better contact with them. Let me see if Charlie is here and we can work in a chat.
Just connected to WA5AIR hub in persistent mode and both ends show Transceive as they should.
Most of the time, I connect and get a Monitor/Receive status, but at the other end, the connection is in Transceive and works normally.
