re removing chan_Irlp from App_RPT
Hi Guys, is there a way to disable a Chan_irlp node from asterisk/App_Rpt?
Is there a way to permanently remove a n IRLP node from App_RPT?
Jon VA3RQ
<-- Hi Jon; add this to the modules.conf file:
noload=chan_irlp.so
(same goes with chan_echolink.so since you're not using that either).
<-- Blow out the /home/irlp directory. Then remove the following from /etc/rc.d/rc.local:
# THESE LINES ARE ADDED FOR THE IRLP SYSTEM
/home/irlp/custom/rc.irlp
Cheers!
Ramesh.
