Still trying to get dahdi_dummy installed on a raspberry pi. The procedure results in the error:
’ You do not appear to have the sources for the 4.9.80-v7+ kernel installed.
So there is a sources problem. Educating myself, I find I need to update my kernel headers.
All documentation says to use: sudo apt install raspberrypi-kernel-headers. When I try, all I get is:
Unable to locate package raspberrypi-kernel-headers. ( and YES, I did do apt-get update ).
Can someone point me to information on how to resolve this?
https://github.com/raspberrypi/firmware/releases/tag/1.20180313
this should contain the source for your kernel.
But I cant confirm how to install them. It is not a package.
Maybe someone with more knowledge then me will be able to help you.
Le ven. 17 avr. 2020 à 10:46, lengriff@optimum.net via AllStarLink Discussion Groups noreply@community.allstarlink.org a écrit :
lengriff
April 17
https://github.com/raspberrypi/firmware/tree/b1a7f4aea6cbd380319c2849ecc5988f9a4dba70
this is the link to download the master at that revision
lengriff
April 17
