Hello. Anyone have luck with a ASL3 on a Raspberry Pi2B? I get a rainbow screen and 7 LED blinks on the Pi, which according to Google means the kernel is not found. I’ve tried to image two SDcards with the same results (using Raspberry Pi Imager 1.8.5)
My old Pi2 image has a kernel.img file, while the new Debian 12 image does not. I have tried a few things but no luck. Here is a list of the files in the boot partition:
Directory of D:\
06/24/2024 05:54 PM overlays
05/29/2024 02:04 PM 32,199 bcm2710-rpi-2-b.dtb
06/24/2024 05:56 PM 1,594 LICENCE.broadcom
06/24/2024 06:16 PM 12,146,428 initramfs_2712
05/29/2024 02:04 PM 35,026 bcm2710-rpi-3-b-plus.dtb
05/29/2024 02:04 PM 34,391 bcm2710-rpi-3-b.dtb
05/29/2024 02:04 PM 32,102 bcm2710-rpi-cm3.dtb
05/29/2024 02:04 PM 33,368 bcm2710-rpi-zero-2-w.dtb
05/29/2024 02:04 PM 33,368 bcm2710-rpi-zero-2.dtb
05/29/2024 02:04 PM 55,804 bcm2711-rpi-4-b.dtb
05/29/2024 02:04 PM 55,808 bcm2711-rpi-400.dtb
05/29/2024 02:04 PM 38,349 bcm2711-rpi-cm4-io.dtb
05/29/2024 02:04 PM 56,444 bcm2711-rpi-cm4.dtb
05/29/2024 02:04 PM 53,215 bcm2711-rpi-cm4s.dtb
05/29/2024 02:04 PM 80,218 bcm2712-rpi-5-b.dtb
05/29/2024 02:04 PM 80,643 bcm2712-rpi-cm5-cm4io.dtb
05/29/2024 02:04 PM 80,635 bcm2712-rpi-cm5-cm5io.dtb
05/29/2024 02:04 PM 80,202 bcm2712d0-rpi-5-b.dtb
06/24/2024 05:56 PM 52,476 bootcode.bin
07/04/2024 01:21 PM 234 cmdline.txt
06/24/2024 06:19 PM 1,248 config.txt
06/24/2024 05:56 PM 7,303 fixup.dat
06/24/2024 05:56 PM 5,436 fixup4.dat
06/24/2024 05:56 PM 3,210 fixup4cd.dat
06/24/2024 05:56 PM 8,423 fixup4db.dat
06/24/2024 05:56 PM 8,425 fixup4x.dat
06/24/2024 05:56 PM 3,210 fixup_cd.dat
06/24/2024 05:56 PM 10,266 fixup_db.dat
06/24/2024 05:56 PM 10,266 fixup_x.dat
06/24/2024 05:56 PM 9,276,375 kernel8.img
06/24/2024 05:56 PM 9,277,371 kernel_2712.img
06/24/2024 05:56 PM 2,981,376 start.elf
06/24/2024 05:56 PM 2,257,216 start4.elf
06/24/2024 05:56 PM 809,884 start4cd.elf
06/24/2024 05:56 PM 3,754,312 start4db.elf
06/24/2024 05:56 PM 3,004,808 start4x.elf
06/24/2024 05:56 PM 809,884 start_cd.elf
06/24/2024 05:56 PM 4,826,216 start_db.elf
06/24/2024 05:56 PM 3,728,456 start_x.elf
06/24/2024 06:15 PM 12,147,981 initramfs8
03/15/2024 03:08 PM 145 issue.txt
06/24/2024 05:51 PM 0 ssh
06/24/2024 05:51 PM 1,841 allstarlink3-wpa-supplicant.txt
07/04/2024 01:21 PM 2,004 firstrun.sh
43 File(s) 65,918,160 bytes
Thanks. 73
Kyle
K0KN
