Hello,
Is there a menu option in ASL to help setup the wifi on the Raspberry Pi image 2.0 beta?
Or do I just need to follow setup instructions for the Pi OS?
Hello,
As I remember it, I had to install the pi wifi utilities and set-up within that menu and/or edit the files manually.
Use OS stated remedy’s, it is not a built-in function.
Thank you for the reply. I will get it working. I was just looking for the shortcut.
Looks like I can run this command “Sudo wifi-setup”
I found the web page I had used when I did this…
raspi-config
I think in my case, I had to install the utilities. Not sure how the image is packed now.
If you use MAC filtering, don’t forget to include your pi.
The wiki was updated…
https://wiki.allstarlink.org/wiki/WiFi_on_RASPI
