Raspberry pi dial uri eeprom broken?
I just set up a new node using a raspberry pi and the dial distribution. I have a uri with an eeprom in it. It was tuned and config saved on the EEPROM. On startup I get the message USB Adapter has no EEPROM installed or Checksum BAD on channel usbXXXXX.
I then retuned the URI and did a radio tune save and asterisk said it was saving to the eeprom. Then reloaded asterisk and go the same message as above.
Did the whole procedure again using another URI and EEPROM. SAME PROBLEM.
Tried both URIs on my x86 acid box and it worked fine.
So is this a dial on raspberry pi problem or does this happen on x86 too?
Thanks & 73,
Scott KB2EAR
Scott,
I just tried a cable with the EEPROM installed on RPi2 DIAL with both simple USB channel driver and USB radio channel driver.
It saved and loaded the data from the EEPROM fine. Would you zip up your usbradio.conf and rpt.conf and send them to me so I can test again.
Thanks, Steve N4IRS
Thanks & 73,
Scott KB2EAR
"Anything is possible if you don't know what you are talking about."
1st Law of Logic
Scott,
Thanks, Steve N4IRS
above.
Thanks & 73,
Scott KB2EAR
usbradio.zip (2.01 KB)
-----Original Message-----
Sent: Tuesday, November 17, 2015 8:44 PM
To: Scott Weis <kb2ear@kb2ear.net>; App_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Raspberry pi dial uri eeprom broken?
1st Law of Logic
