I am building a radioless node. Where can I find all the configuration settings? Using a Raspberry pi 3 and a RA-20 interface. I actually built this a long time ago but the sd card failed and I can not remember where I found all the settings. Basically from the time you put the card in and fire up the node. Settings for a radio less or RF less node. Any help would be great. Thank you
This guide covers all the .conf settings (which are the same regardless of if RPi or x64).
