I followed the instructions at ohnosec.ord/drupal.node/193 to switch over to simpleusb on a ACID node. Up to the delete /etc/init.d/usbradio and the touch /etc/init.d/simpleusb which neither was located there. So I went and reinstalled ACID and changed my Allstart node config to reflect using simpleusb. This is a private node that I am running so after the install I changed all the conf files to reflect my private node. Then I went in to the Asterisk cli to tune everything up. There I ran into a problem there is no simpleusb-tune-menu or radio tune commands. What I am missing here? How do you tune the radio with simpleusb?
I typed Help as the Asterisk cli and it shows nothing for any sort of tune.
Try on the shell outside of the asterisk cli. If for some reason that fails, the binaries you are looking for should be located at /usr/sbin/.
Best,
Matt Dodd
ยทยทยท
