radio-tune-menu problem
Folks, I've searched for solutions with this. But downloaded RAT_RC1.img and put it in a SD card, etc, Pi3, etc. First issue was the nodesetup erroring out and not setting up things like which channel driver and so on, but I manually setup rpt.conf to be simpleusb and the right node number, manually edited modules.conf to enable simpleusb, manually setup simpleusb.conf. Now I have the node where it works. Passes audio but went to setup levels. RX audio to net is too high. I made a file for tune factrors in /etc/asterisk
simpleusb_tune_usb_27170.conf :
[usb]
; name=usb
; devicenum=0
devstr=3-1
rxmixerset=25
txmixaset=999
txmixbset=999
The txmix settings work, the rx ones don't seem to. Same hardware, other distro and could get the audio right.
but...
radio-tune-menu won't run:
root@repeater:~# radio-tune-menu
Error parsing device parameters
I'm lost as to where to look. Running on my nodes either limey or ACID. I had another person's image for the Pi but arch linux is a nightmare (and this coming from a 21 year veteran of slackware). Building a node for N5JGX, which I along with W8VT will be admin for. So I downloaded RAT_RC1 figuring I'd stick with the successors, heirs or designee of the founder.
But hope someone can give me some direction where to look.
If it can't parse device parameters...where do they live??
Thanks All y'all
GeorgeC
W2DB 2360
George Csahanin
10100 Carson Ranch Rd.
Crowley, TX 76036
682-708-5716 home
401-338-0568 cel
http://dyb.com
PLEASE NOTE: Effective January 1, 2018 george@dyb.com will no longer function
USE george@w2db.com
Radio tune menu is for usbradio channel driver. use simple-usb-tune.
[usb]
; name=usb
; devicenum=0
devstr=3-1
rxmixerset=25
txmixaset=999
txmixbset=999
but...
Thanks All y'all
GeorgeC
W2DB 2360
Correction:
simpleusb-tune-menu
[usb]
; name=usb
; devicenum=0
devstr=3-1
rxmixerset=25
txmixaset=999
txmixbset=999
but...
Thanks All y'all
GeorgeC
W2DB 2360
Hi gorgeous
Try using the command
simpleusb-tune- menu
That is the correct one not
radio- tune- menu
The above is for the chan_ USB not chan_ simple
Ken n1dot
On Aug 29, 2017 13:30, “George Csahanin” george@dyb.com wrote:
Folks, I’ve searched for solutions with this. But downloaded RAT_RC1.img and put it in a SD card, etc, Pi3, etc. First issue was the nodesetup erroring out and not setting up things like which channel driver and so on, but I manually setup rpt.conf to be simpleusb and the right node number, manually edited modules.conf to enable simpleusb, manually setup simpleusb.conf. Now I have the node where it works. Passes audio but went to setup levels. RX audio to net is too high. I made a file for tune factrors in /etc/asterisk
[usb]
; name=usb
; devicenum=0
devstr=3-1
rxmixerset=25
txmixaset=999
txmixbset=999
The txmix settings work, the rx ones don’t seem to. Same hardware, other distro and could get the audio right.
but…
radio-tune-menu won’t run:
I’m lost as to where to look. Running on my nodes either limey or ACID. I had another person’s image for the Pi but arch linux is a nightmare (and this coming from a 21 year veteran of slackware). Building a node for N5JGX, which I along with W8VT will be admin for. So I downloaded RAT_RC1 figuring I’d stick with the successors, heirs or designee of the founder.
If it can’t parse device parameters…where do they live??
Thanks All y’all
GeorgeC
W2DB 2360
George Csahanin
Crowley, TX 76036
682-708-5716 home
401-338-0568 cel
http://dyb.com
USE george@w2db.com
