radio-tune-menu error
this is new to me.
Some things have changed. I have not had these errors when installed and
setup my other two nodes in the first couple months of this year. I
downloaded the configs from the portal, did the radio-tune-menu, and it
went right to the menu on the other nodes.
On the new node, I get:
Error parsing device parameters
I'm comparing the new node stuff versus the old, and the only thing
different is the usb[nodenumber].
I did a lsusb, saw the device was plugged in, and same info as the other
machine.
~Benjamin, K9LFZ
The portal config does add the node number, usb[nodenumber], to the config files like you said. But if you only have one usb device the [nodenumber] is not needed because usb by itself is unique. If your older node was configured by hand it’s likely to have only usb as the designation. Whatever the designation in the usb config is, it has to match the rxchannel= in the node stanza of rpt.conf.
Be aware there are two possible usb config files; simpleusb and usbradio. I looks like you are using usbradio but I thought I’d mention it just incase there is a stray simpleusb.conf file on your system somehow.
Tim
:wq
On Nov 19, 2013, at 12:41 PM, Benjamin L. Naber <benjamin@kb9lfz.com> wrote:
this is new to me.
machine.
~Benjamin, K9LFZ
ohnosec.org
Fail.
Very frustrating with no log output.
The settings on this machine are identical to my working node that uses
the Limey Linux for Intel.
Mind you, I've made zero changes to rpt.conf. Only to usbradio.conf, and
that was to the node designation, which it is now back to what it was
after downloading the configs from the portal
There are a few of you that do not have anything helpful. If you are
tempted to saying anything useful, save the electrons.
~Benjamin, KB9LFZ
Working limely linux i686 allstar node 28569
my NOT working node RPT.conf:
; Radio Repeater configuration file (for use with app_rpt)
; Your Repeater
[29572] ; Change this to your assigned node number
rxchannel=Radio/usb29572
duplex=1
erxgain=-3
etxgain=3
;controlstates=controlstates
scheduler=schedule29572
morse=morse29572
macro=macro29572
functions=functions29572
phone_functions=functions29572
link_functions=functions29572
telemetry=telemetry
wait_times=wait-times
context = radio
callerid = "Repeater" <0000000000>
idrecording = |iKB9LFZ
accountcode=RADIO
hangtime=100
althangtime=100
totime=170000
idtime=540000
politeid=3000
idtalkover=|iKB9LFZ
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
;nolocallinkct=0
;eannmode=1
;connpgm=yourconnectprogram
;discpgm=yourdisconnectprogram
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
;lnkacttimerwarn=30seconds
;remote_inact_timeout=1800
;remote_timeout=3600
nounkeyct=0
;holdofftelem=0
beaconing=0
; *** Status Reporting ***
; Uncomment the either group following two statpost lines to report the
status of your node to stats.allstarlink.org
; depending on whether you are running ACID or Limey Linux.
; ** For ACID ***
;statpost_program=/usr/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
;statpost_url=http://stats.allstarlink.org/uhandler.php ; Status
updates
; ** For Limey Linux **
statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
; Morse code parameters, these are common to all repeaters.
[morse29572]
speed=18
frequency=800
amplitude=4096
idfrequency=750
idamplitude=1024
[schedule29572]
;dtmf_function = m h dom mon dow ; ala cron, star is
implied
[functions29572]
1=ilink,1
2=ilink,2
3=ilink,3
4=ilink,4
5=macro,1
70=ilink,5
71=ilink,6
72=ilink,7
73=ilink,15
74=ilink,16
75=ilink,8
80=status,1
81=status,2
6=autopatchup,noct=1,farenddisconnect=1,dialtime=20000 ; Autopatch up
0=autopatchdn ; Autopatch down
;989=cop,4
980=status,3
99=cop,6
; Place command macros here
[macro29572]
;[29567] ; Change this to your assigned node number
;rxchannel=Radio/usb29567
;duplex=1
;erxgain=-3
;etxgain=3
;scheduler=schedule29567
;morse=morse29567
;macro=macro29567
;functions=functions29567
;phone_functions=functions29567
;link_functions=functions29567
;telemetry=telemetry
;wait_times=wait-times
;context = radio
;callerid = "Repeater" <0000000000>
;idrecording = |iKB9LFZ
;accountcode=RADIO
;hangtime=100
;althangtime=100
;totime=170000
;idtime=540000
;politeid=3000
;idtalkover=|iKB9LFZ
;unlinkedct=ct2
;remotect=ct3
;linkunkeyct=ct8
;nolocallinkct=0
;eannmode=1
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
;nounkeyct=0
;holdofftelem=0
;beaconing=0
; ** For ACID ***
updates
;statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
updates
;[morse29567]
;speed=18
;frequency=800
;amplitude=4096
;idfrequency=750
;idamplitude=1024
;[schedule29567]
implied
;[functions29567]
;1=ilink,1
;2=ilink,2
;3=ilink,3
;4=ilink,4
;5=macro,1
;70=ilink,5
;71=ilink,6
;72=ilink,7
;73=ilink,15
;74=ilink,16
;75=ilink,8
;80=status,1
;81=status,2
;6=autopatchup,noct=1,farenddisconnect=1,dialtime=20000 ; Autopatch up
;0=autopatchdn ; Autopatch down
;989=cop,4
;980=status,3
99=cop,6
;[macro29567]
;[telemetry]
;ct1=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
;ct2=|t(660,880,150,2048)
;ct3=|t(440,0,150,4096)
;ct4=|t(550,0,150,2048)
;ct5=|t(660,0,150,2048)
;ct6=|t(880,0,150,2048)
;ct7=|t(660,440,150,2048)
;ct8=|t(700,1100,150,2048)
;remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000);
;remotemon=|t(1209,0,50,2048)
;cmdmode=|t(900,903,200,2048)
;functcomplete=|t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
;patchup=rpt/callproceeding
;patchdown=rpt/callterminated
; A section for wait times can be defined for every repeater
;[wait-times]
;telemwait=2000
;idwait=500
;unkeywait=2000
;calltermwait=2000
; This is where you define your nodes which cam be connected to.
[nodes]
; for your locak nodes, and private (off of allstar link) nodes here.
29572 = radio@127.0.0.1/29572,NONE
;29567 = radio@127.0.0.1/29567,NONE
; Memories for remote bases
[memory]
;00 = 146.580,100.0,m
;01 = 147.030,103.5,m+t
;02 = 147.240,103.5,m+t
;03 = 147.765,79.7,m-t
;04 = 146.460,100.0,m
;05 = 146.550,100.0,m
#includeifexists custom/rpt.conf
**** 29567 usbradio.conf*****
; Usbradio channel driver Configuration File
[general]
[usb29567]
hdwtype=0
rxboost=1
txboost=0
rxctcssrelax=1
txctcssdefault=100.0
rxctcssfreqs=127.3
txctcssfreqs=127.3
;rxctcssoverride=0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=no
txlimonly=no
txtoctype=no
txmixa=voice
txmixb=no
invertptt=0
duplex=0
rxondelay=0
rxnoisefiltype=0
eeprom=0
;[usb29572]
;hdwtype=0
;rxboost=1
;txboost=1
;rxctcssrelax=1
;txctcssdefault=100.0
;rxctcssfreqs=100.0
;txctcssfreqs=100.0
;rxctcssoverride=0
;carrierfrom=dsp
;ctcssfrom=dsp
;rxdemod=flat
;txprelim=yes
;txlimonly=no
;txtoctype=notone
;txmixa=composite
;txmixb=0
;invertptt=0
;duplex=1
;rxondelay=0
;rxnoisefiltype=0
;eeprom=0
; external paralle port pin usage
pp3 = ptt
pp4 = out0 ; aux 1
pp5 = out1 ; aux 2
pp6 = out2 ; aux 3
; pp11 = cor
#includeifexists custom/usbradio.conf
********** zapata.conf *******
; zapata.conf for systems with radiopci cards
[channels]
signalling=em_txrx ; This needs to match the number of channels used in
zapata.conf and rpt.conf
;channel = 1
;channel = 2
;channel = 3
;channel = 4
group=9
channel=pseudo
; End of file
Tim
:wq
> this is new to me.
> machine.
> ~Benjamin, K9LFZ
> App_rpt-users mailing list
> ohnosec.org
There is no console messages if you do 'asterisk -rvvv’? Is that what you mean by log output?
Tim
:wq
On Nov 19, 2013, at 3:56 PM, Benjamin L. Naber <benjamin@kb9lfz.com> wrote:
Fail.
~Benjamin, KB9LFZ
; Your Repeater
duplex=1
erxgain=-3
etxgain=3
morse=morse29572
macro=macro29572
telemetry=telemetry
context = radio
accountcode=RADIO
hangtime=100
althangtime=100
totime=170000
idtime=540000
politeid=3000
idtalkover=|iKB9LFZ
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
;nolocallinkct=0
;eannmode=1
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
nounkeyct=0
;holdofftelem=0
beaconing=0
; ** For ACID ***
updates
[morse29572]
speed=18
frequency=800
amplitude=4096
idfrequency=750
idamplitude=1024
[schedule29572]
implied
[functions29572]
1=ilink,1
2=ilink,2
3=ilink,3
4=ilink,4
5=macro,1
70=ilink,5
71=ilink,6
72=ilink,7
73=ilink,15
74=ilink,16
75=ilink,8
80=status,1
81=status,2
;989=cop,4
980=status,3
99=cop,6
[macro29572]
;duplex=1
;erxgain=-3
;etxgain=3
;morse=morse29567
;macro=macro29567
;context = radio
;accountcode=RADIO
;hangtime=100
;althangtime=100
;totime=170000
;idtime=540000
;politeid=3000
;unlinkedct=ct2
;remotect=ct3
;linkunkeyct=ct8
;nolocallinkct=0
;eannmode=1
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
;nounkeyct=0
;holdofftelem=0
;beaconing=0
; ** For ACID ***
updates
updates
;[morse29567]
;speed=18
;frequency=800
;amplitude=4096
;idfrequency=750
;idamplitude=1024
;[schedule29567]
implied
;[functions29567]
;1=ilink,1
;2=ilink,2
;3=ilink,3
;4=ilink,4
;5=macro,1
;70=ilink,5
;71=ilink,6
;72=ilink,7
;73=ilink,15
;74=ilink,16
;75=ilink,8
;80=status,1
;81=status,2
;989=cop,4
;980=status,3
99=cop,6
;[macro29567]
;[telemetry]
;[wait-times]
;telemwait=2000
;idwait=500
;unkeywait=2000
;calltermwait=2000
[nodes]
[memory]
[general]
[usb29567]
hdwtype=0
rxboost=1
txboost=0
rxctcssrelax=1
rxctcssfreqs=127.3
txctcssfreqs=127.3
;rxctcssoverride=0
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=no
txlimonly=no
txtoctype=no
txmixa=voice
txmixb=no
invertptt=0
duplex=0
rxondelay=0
rxnoisefiltype=0
eeprom=0
;[usb29572]
;hdwtype=0
;rxboost=1
;txboost=1
;rxctcssrelax=1
;rxctcssfreqs=100.0
;txctcssfreqs=100.0
;rxctcssoverride=0
;carrierfrom=dsp
;ctcssfrom=dsp
;rxdemod=flat
;txprelim=yes
;txlimonly=no
;txtoctype=notone
;txmixa=composite
;txmixb=0
;invertptt=0
;duplex=1
;rxondelay=0
;rxnoisefiltype=0
;eeprom=0
pp3 = ptt
pp4 = out0 ; aux 1
pp5 = out1 ; aux 2
pp6 = out2 ; aux 3
; pp11 = cor
[channels]
;channel = 1
;channel = 2
;channel = 3
;channel = 4
group=9
channel=pseudo
; End of file
Tim
:wq
this is new to me.
machine.
~Benjamin, K9LFZ
ohnosec.org
for radio-tune-menu
asterisk keeps dying because there isn't a file generated by radio tune
menu...
[Nov 19 17:13:36] WARNING[3196]: chan_usbradio.c:1729 hidthread: File
usbradio_tune_usb29572.conf not found, device usb29572 using default
parameters.
I tried making one an exact copy of my working node to see if I can get
radio tune menu to work that way, but no dice.
Tim
:wq
> Fail.
> ~Benjamin, KB9LFZ
> ; Your Repeater
> duplex=1
> erxgain=-3
> etxgain=3
> morse=morse29572
> macro=macro29572
> telemetry=telemetry
> context = radio
> accountcode=RADIO
> hangtime=100
> althangtime=100
> totime=170000
> idtime=540000
> politeid=3000
> idtalkover=|iKB9LFZ
> unlinkedct=ct2
> remotect=ct3
> linkunkeyct=ct8
> ;nolocallinkct=0
> ;eannmode=1
> ;lnkactenable=0
> ;lnkacttime=1800
> ;lnkactmacro=*52
> nounkeyct=0
> ;holdofftelem=0
> beaconing=0
> ; ** For ACID ***
> updates
> [morse29572]
> speed=18
> frequency=800
> amplitude=4096
> idfrequency=750
> idamplitude=1024
> [schedule29572]
> implied
> [functions29572]
> 1=ilink,1
> 2=ilink,2
> 3=ilink,3
> 4=ilink,4
> 5=macro,1
> 70=ilink,5
> 71=ilink,6
> 72=ilink,7
> 73=ilink,15
> 74=ilink,16
> 75=ilink,8
> 80=status,1
> 81=status,2
> ;989=cop,4
> 980=status,3
> 99=cop,6
> [macro29572]
> ;duplex=1
> ;erxgain=-3
> ;etxgain=3
> ;morse=morse29567
> ;macro=macro29567
> ;context = radio
> ;accountcode=RADIO
> ;hangtime=100
> ;althangtime=100
> ;totime=170000
> ;idtime=540000
> ;politeid=3000
> ;unlinkedct=ct2
> ;remotect=ct3
> ;linkunkeyct=ct8
> ;nolocallinkct=0
> ;eannmode=1
> ;lnkactenable=0
> ;lnkacttime=1800
> ;lnkactmacro=*52
> ;nounkeyct=0
> ;holdofftelem=0
> ;beaconing=0
> ; ** For ACID ***
> updates
> updates
> ;[morse29567]
> ;speed=18
> ;frequency=800
> ;amplitude=4096
> ;idfrequency=750
> ;idamplitude=1024
> ;[schedule29567]
> implied
> ;[functions29567]
> ;1=ilink,1
> ;2=ilink,2
> ;3=ilink,3
> ;4=ilink,4
> ;5=macro,1
> ;70=ilink,5
> ;71=ilink,6
> ;72=ilink,7
> ;73=ilink,15
> ;74=ilink,16
> ;75=ilink,8
> ;80=status,1
> ;81=status,2
> ;989=cop,4
> ;980=status,3
> 99=cop,6
> ;[macro29567]
> ;[telemetry]
> ;[wait-times]
> ;telemwait=2000
> ;idwait=500
> ;unkeywait=2000
> ;calltermwait=2000
> [nodes]
> [memory]
> [general]
> [usb29567]
> hdwtype=0
> rxboost=1
> txboost=0
> rxctcssrelax=1
> rxctcssfreqs=127.3
> txctcssfreqs=127.3
> ;rxctcssoverride=0
> carrierfrom=dsp
> ctcssfrom=dsp
> rxdemod=flat
> txprelim=no
> txlimonly=no
> txtoctype=no
> txmixa=voice
> txmixb=no
> invertptt=0
> duplex=0
> rxondelay=0
> rxnoisefiltype=0
> eeprom=0
> ;[usb29572]
> ;hdwtype=0
> ;rxboost=1
> ;txboost=1
> ;rxctcssrelax=1
> ;rxctcssfreqs=100.0
> ;txctcssfreqs=100.0
> ;rxctcssoverride=0
> ;carrierfrom=dsp
> ;ctcssfrom=dsp
> ;rxdemod=flat
> ;txprelim=yes
> ;txlimonly=no
> ;txtoctype=notone
> ;txmixa=composite
> ;txmixb=0
> ;invertptt=0
> ;duplex=1
> ;rxondelay=0
> ;rxnoisefiltype=0
> ;eeprom=0
> pp3 = ptt
> pp4 = out0 ; aux 1
> pp5 = out1 ; aux 2
> pp6 = out2 ; aux 3
> ; pp11 = cor
> [channels]
> ;channel = 1
> ;channel = 2
> ;channel = 3
> ;channel = 4
> group=9
> channel=pseudo
> ; End of file
>> Tim
>> :wq
>>> this is new to me.
>>> machine.
>>> ~Benjamin, K9LFZ
>>> ohnosec.org
with fake usbradio_tune_usb29572.conf in place...
[Nov 19 17:39:59] NOTICE[1500]: app_rpt.c:22002 rpt_master: RPT thread
restarted on 29572
[Nov 19 17:39:59] WARNING[1500]: app_rpt.c:22014 rpt_master: rpt_thread
restarted on node 29572
[Nov 19 17:39:59] WARNING[1544]: channel.c:3051 ast_request: No channel
type registered for 'Zap'
rpt:Sorry unable to obtain pseudo channel
[Nov 19 17:39:59] WARNING[1545]: chan_usbradio.c:1728 hidthread: Loaded
parameters from usbradio_tune_usb29572.conf for device usb29572
Tim
:wq
> Fail.
> ~Benjamin, KB9LFZ
> ; Your Repeater
> duplex=1
> erxgain=-3
> etxgain=3
> morse=morse29572
> macro=macro29572
> telemetry=telemetry
> context = radio
> accountcode=RADIO
> hangtime=100
> althangtime=100
> totime=170000
> idtime=540000
> politeid=3000
> idtalkover=|iKB9LFZ
> unlinkedct=ct2
> remotect=ct3
> linkunkeyct=ct8
> ;nolocallinkct=0
> ;eannmode=1
> ;lnkactenable=0
> ;lnkacttime=1800
> ;lnkactmacro=*52
> nounkeyct=0
> ;holdofftelem=0
> beaconing=0
> ; ** For ACID ***
> updates
> [morse29572]
> speed=18
> frequency=800
> amplitude=4096
> idfrequency=750
> idamplitude=1024
> [schedule29572]
> implied
> [functions29572]
> 1=ilink,1
> 2=ilink,2
> 3=ilink,3
> 4=ilink,4
> 5=macro,1
> 70=ilink,5
> 71=ilink,6
> 72=ilink,7
> 73=ilink,15
> 74=ilink,16
> 75=ilink,8
> 80=status,1
> 81=status,2
> ;989=cop,4
> 980=status,3
> 99=cop,6
> [macro29572]
> ;duplex=1
> ;erxgain=-3
> ;etxgain=3
> ;morse=morse29567
> ;macro=macro29567
> ;context = radio
> ;accountcode=RADIO
> ;hangtime=100
> ;althangtime=100
> ;totime=170000
> ;idtime=540000
> ;politeid=3000
> ;unlinkedct=ct2
> ;remotect=ct3
> ;linkunkeyct=ct8
> ;nolocallinkct=0
> ;eannmode=1
> ;lnkactenable=0
> ;lnkacttime=1800
> ;lnkactmacro=*52
> ;nounkeyct=0
> ;holdofftelem=0
> ;beaconing=0
> ; ** For ACID ***
> updates
> updates
> ;[morse29567]
> ;speed=18
> ;frequency=800
> ;amplitude=4096
> ;idfrequency=750
> ;idamplitude=1024
> ;[schedule29567]
> implied
> ;[functions29567]
> ;1=ilink,1
> ;2=ilink,2
> ;3=ilink,3
> ;4=ilink,4
> ;5=macro,1
> ;70=ilink,5
> ;71=ilink,6
> ;72=ilink,7
> ;73=ilink,15
> ;74=ilink,16
> ;75=ilink,8
> ;80=status,1
> ;81=status,2
> ;989=cop,4
> ;980=status,3
> 99=cop,6
> ;[macro29567]
> ;[telemetry]
> ;[wait-times]
> ;telemwait=2000
> ;idwait=500
> ;unkeywait=2000
> ;calltermwait=2000
> [nodes]
> [memory]
> [general]
> [usb29567]
> hdwtype=0
> rxboost=1
> txboost=0
> rxctcssrelax=1
> rxctcssfreqs=127.3
> txctcssfreqs=127.3
> ;rxctcssoverride=0
> carrierfrom=dsp
> ctcssfrom=dsp
> rxdemod=flat
> txprelim=no
> txlimonly=no
> txtoctype=no
> txmixa=voice
> txmixb=no
> invertptt=0
> duplex=0
> rxondelay=0
> rxnoisefiltype=0
> eeprom=0
> ;[usb29572]
> ;hdwtype=0
> ;rxboost=1
> ;txboost=1
> ;rxctcssrelax=1
> ;rxctcssfreqs=100.0
> ;txctcssfreqs=100.0
> ;rxctcssoverride=0
> ;carrierfrom=dsp
> ;ctcssfrom=dsp
> ;rxdemod=flat
> ;txprelim=yes
> ;txlimonly=no
> ;txtoctype=notone
> ;txmixa=composite
> ;txmixb=0
> ;invertptt=0
> ;duplex=1
> ;rxondelay=0
> ;rxnoisefiltype=0
> ;eeprom=0
> pp3 = ptt
> pp4 = out0 ; aux 1
> pp5 = out1 ; aux 2
> pp6 = out2 ; aux 3
> ; pp11 = cor
> [channels]
> ;channel = 1
> ;channel = 2
> ;channel = 3
> ;channel = 4
> group=9
> channel=pseudo
> ; End of file
>> Tim
>> :wq
>>> this is new to me.
>>> machine.
>>> ~Benjamin, K9LFZ
>>> ohnosec.org
Fix the Zap error first. Check these two files. If on Limey be sure to svcfg and then reboot.
cat /etc/zaptel.conf
# zaptel.conf
loadzone = us
defaultzone=us
# End of file
cat /etc/asterisk/zapata.conf
; zapata.conf for systems with usbradio fobs
[channels]
signalling=em_txrx
group=9
channel=pseudo
; End of file
Tim
:wq
I have had this problem before. If I wait a few minutes then it works.
Not sure why it cant open the device sometimes.
Lee
-----Original Message-----
To: Tim Sawyer tim.sawyer@mac.com
Cc: app_rpt mailing list app_rpt-users@ohnosec.org
Sent: Tue, Nov 19, 2013 5:42 pm
Subject: Re: [App_rpt-users] radio-tune-menu error
restarted on 29572
> Tim
> :wq
> > On Nov 19, 2013, at 3:56 PM, Benjamin L. Naber <benjamin@kb9lfz.com > wrote:
> > > Fail.
> > > > ~Benjamin, KB9LFZ
> > ; Your Repeater
> > > > > > [29572] ; Change this to your assigned node number > > > > rxchannel=Radio/usb29572
> > duplex=1
> > erxgain=-3
> > etxgain=3
> > morse=morse29572
> > macro=macro29572
> > telemetry=telemetry
> > context = radio
> > accountcode=RADIO
> > hangtime=100
> > althangtime=100
> > totime=170000
> > idtime=540000
> > politeid=3000
> > > > idtalkover=|iKB9LFZ
> > unlinkedct=ct2
> > remotect=ct3
> > linkunkeyct=ct8
> > ;nolocallinkct=0
> > ;eannmode=1
> > ;lnkactenable=0
> > ;lnkacttime=1800
> > ;lnkactmacro=*52
> > nounkeyct=0
> > ;holdofftelem=0
> > beaconing=0
> > > > ; ** For ACID ***
> > ;statpost_program=/usr/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null > > ;statpost_url=[http://stats.allstarlink.org/uhandler.php](http://stats.allstarlink.org/uhandler.php) ; Status
> > updates > > > > ; ** For Limey Linux **
> > statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null > > statpost_url=[http://stats.allstarlink.org/uhandler.php](http://stats.allstarlink.org/uhandler.php) ; Status updates > > > > ;
> > > > [morse29572]
> > > > speed=18
> > frequency=800
> > amplitude=4096
> > idfrequency=750
> > idamplitude=1024
> > > > [schedule29572] > > ;dtmf_function = m h dom mon dow ; ala cron, star is
> > implied > > > > > > [functions29572]
> > 1=ilink,1
> > 2=ilink,2
> > 3=ilink,3
> > 4=ilink,4
> > 5=macro,1
> > 70=ilink,5
> > 71=ilink,6
> > 72=ilink,7
> > 73=ilink,15
> > 74=ilink,16
> > 75=ilink,8
> > > > 80=status,1
> > 81=status,2
> > > > ;989=cop,4
> > 980=status,3
> > 99=cop,6
> > > > [macro29572]
> > > > > > > > > > ;[29567] ; Change this to your assigned node number > > > > ;rxchannel=Radio/usb29567
> > ;duplex=1
> > ;erxgain=-3
> > ;etxgain=3
> > ;morse=morse29567
> > ;macro=macro29567
> > ;context = radio
> > ;accountcode=RADIO
> > ;hangtime=100
> > ;althangtime=100
> > ;totime=170000
> > ;idtime=540000
> > ;politeid=3000
> > ;unlinkedct=ct2
> > ;remotect=ct3
> > ;linkunkeyct=ct8
> > ;nolocallinkct=0
> > ;eannmode=1
> > ;lnkactenable=0
> > ;lnkacttime=1800
> > ;lnkactmacro=*52
> > ;nounkeyct=0
> > ;holdofftelem=0
> > ;beaconing=0
> > > > ; ** For ACID ***
> > ;statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null > > ;statpost_url=[http://stats.allstarlink.org/uhandler.php](http://stats.allstarlink.org/uhandler.php) ; Status
> > updates > > > > ;
> > > > ;[morse29567]
> > > > ;speed=18
> > ;frequency=800
> > ;amplitude=4096
> > ;idfrequency=750
> > ;idamplitude=1024
> > > > ;[schedule29567] > > ;dtmf_function = m h dom mon dow ; ala cron, star is
> > implied > > > > > > ;[functions29567]
> > ;1=ilink,1
> > ;2=ilink,2
> > ;3=ilink,3
> > ;4=ilink,4
> > ;5=macro,1
> > ;70=ilink,5
> > ;71=ilink,6
> > ;72=ilink,7
> > ;73=ilink,15
> > ;74=ilink,16
> > ;75=ilink,8
> > > > ;80=status,1
> > ;81=status,2
> > > > ;989=cop,4
> > ;980=status,3
> > 99=cop,6
> > > > ;[macro29567]
> > > > > > > > ;[telemetry]
> > ;ct2=|t(660,880,150,2048) > > ;ct3=|t(440,0,150,4096) > > ;ct4=|t(550,0,150,2048)
> > ;remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000); > > ;remotemon=|t(1209,0,50,2048) > > ;cmdmode=|t(900,903,200,2048)
> > > > ;[wait-times] > > ;telemwait=2000
> > ;idwait=500
> > ;unkeywait=2000
> > ;calltermwait=2000
> > > > [nodes]
> > > > 29572 = radio@127.0.0.1/29572,NONE > > ;29567 = radio@127.0.0.1/29567,NONE
> > > > [memory]
> > ;05 = 146.550,100.0,m > > > > #includeifexists custom/rpt.conf
> > > > [general]
> > > > [usb29567]
> > > > hdwtype=0 > > rxboost=1
> > txboost=0
> > rxctcssrelax=1
> > rxctcssfreqs=127.3
> > txctcssfreqs=127.3
> > ;rxctcssoverride=0
> > carrierfrom=dsp
> > ctcssfrom=dsp
> > rxdemod=flat
> > txprelim=no
> > txlimonly=no
> > txtoctype=no
> > txmixa=voice
> > txmixb=no
> > invertptt=0
> > duplex=0
> > rxondelay=0
> > rxnoisefiltype=0
> > eeprom=0
> > > > ;[usb29572]
> > > > ;hdwtype=0 > > ;rxboost=1
> > ;txboost=1
> > ;rxctcssrelax=1
> > ;rxctcssfreqs=100.0
> > ;txctcssfreqs=100.0
> > ;rxctcssoverride=0
> > ;carrierfrom=dsp
> > ;ctcssfrom=dsp
> > ;rxdemod=flat
> > ;txprelim=yes
> > ;txlimonly=no
> > ;txtoctype=notone
> > ;txmixa=composite
> > ;txmixb=0
> > ;invertptt=0
> > ;duplex=1
> > ;rxondelay=0
> > ;rxnoisefiltype=0
> > ;eeprom=0
> > pp3 = ptt
> > pp4 = out0 ; aux 1
> > pp5 = out1	; aux 2
> > pp6 = out2	; aux 3
> > ; pp11 = cor
> > > > [channels]
> > ;channel = 1 > > ;channel = 2
> > ;channel = 3
> > ;channel = 4
> > > > group=9
> > channel=pseudo
> > ; End of file
> >> > >> Be aware there are two possible usb config files; simpleusb and usbradio. I looks like you are using usbradio but I thought I’d mention it just incase there is a stray simpleusb.conf file on your system somehow. > >> --
> >> Tim
> >> :wq
> >> > >>> this is new to me.
> >>> machine.
> >>> ~Benjamin, K9LFZ
> >>> [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
Today I tried using “radio-tune-menu” and would get similar errors and core dumps. but using the Asterisk command line interface and "radio tune " commands I had no problems,
Chuck WB9UUS
Lee
restarted on 29572
> Tim
> :wq
> > > Fail.
> > > > ~Benjamin, KB9LFZ
> > ; Your Repeater
> > duplex=1
> > erxgain=-3
> > etxgain=3
> > morse=morse29572
> > macro=macro29572
> > telemetry=telemetry
> > context = radio
> > accountcode=RADIO
> > hangtime=100
> > althangtime=100
> > totime=170000
> > idtime=540000
> > politeid=3000
> > > > idtalkover=|iKB9LFZ
> > unlinkedct=ct2
> > remotect=ct3
> > linkunkeyct=ct8
> > ;nolocallinkct=0
> > ;eannmode=1
> > ;lnkactenable=0
> > ;lnkacttime=1800
> > ;lnkactmacro=*52
> > nounkeyct=0
> > ;holdofftelem=0
> > beaconing=0
> > status of your node to [stats.allstarlink.org](http://stats.allstarlink.org)
> > > > ; ** For ACID ***
> > > > [morse29572]
> > > > speed=18
> > frequency=800
> > amplitude=4096
> > idfrequency=750
> > idamplitude=1024
> > 1=ilink,1
> > 2=ilink,2
> > 3=ilink,3
> > 4=ilink,4
> > 5=macro,1
> > 70=ilink,5
> > 71=ilink,6
> > 72=ilink,7
> > 73=ilink,15
> > 74=ilink,16
> > 75=ilink,8
> > > > 80=status,1
> > 81=status,2
> > > > ;989=cop,4
> > 980=status,3
> > 99=cop,6
> > > > [macro29572]
> > ;duplex=1
> > ;erxgain=-3
> > ;etxgain=3
> > ;morse=morse29567
> > ;macro=macro29567
> > ;context = radio
> > ;accountcode=RADIO
> > ;hangtime=100
> > ;althangtime=100
> > ;totime=170000
> > ;idtime=540000
> > ;politeid=3000
> > ;unlinkedct=ct2
> > ;remotect=ct3
> > ;linkunkeyct=ct8
> > ;nolocallinkct=0
> > ;eannmode=1
> > ;lnkactenable=0
> > ;lnkacttime=1800
> > ;lnkactmacro=*52
> > ;nounkeyct=0
> > ;holdofftelem=0
> > ;beaconing=0
> > > > ; ** For ACID ***
> > updates > > > > ;
> > > > ;[morse29567]
> > > > ;speed=18
> > ;frequency=800
> > ;amplitude=4096
> > ;idfrequency=750
> > ;idamplitude=1024
> > ;1=ilink,1
> > ;2=ilink,2
> > ;3=ilink,3
> > ;4=ilink,4
> > ;5=macro,1
> > ;70=ilink,5
> > ;71=ilink,6
> > ;72=ilink,7
> > ;73=ilink,15
> > ;74=ilink,16
> > ;75=ilink,8
> > > > ;80=status,1
> > ;81=status,2
> > > > ;989=cop,4
> > ;980=status,3
> > 99=cop,6
> > > > ;[macro29567]
> > > > > > > > ;[telemetry]
> > ;idwait=500
> > ;unkeywait=2000
> > ;calltermwait=2000
> > > > [nodes]
> > > > [memory]
> > > > [general]
> > > > [usb29567]
> > txboost=0
> > rxctcssrelax=1
> > rxctcssfreqs=127.3
> > txctcssfreqs=127.3
> > ;rxctcssoverride=0
> > carrierfrom=dsp
> > ctcssfrom=dsp
> > rxdemod=flat
> > txprelim=no
> > txlimonly=no
> > txtoctype=no
> > txmixa=voice
> > txmixb=no
> > invertptt=0
> > duplex=0
> > rxondelay=0
> > rxnoisefiltype=0
> > eeprom=0
> > > > ;[usb29572]
> > ;txboost=1
> > ;rxctcssrelax=1
> > ;rxctcssfreqs=100.0
> > ;txctcssfreqs=100.0
> > ;rxctcssoverride=0
> > ;carrierfrom=dsp
> > ;ctcssfrom=dsp
> > ;rxdemod=flat
> > ;txprelim=yes
> > ;txlimonly=no
> > ;txtoctype=notone
> > ;txmixa=composite
> > ;txmixb=0
> > ;invertptt=0
> > ;duplex=1
> > ;rxondelay=0
> > ;rxnoisefiltype=0
> > ;eeprom=0
> > pp3 = ptt
> > pp4 = out0 ; aux 1
> > pp5 = out1	; aux 2
> > pp6 = out2	; aux 3
> > ; pp11 = cor
> > > > [channels]
> > ;channel = 3
> > ;channel = 4
> > > > group=9
> > channel=pseudo
> > ; End of file
> >> Tim
> >> :wq
> >> > >>> this is new to me.
> >>> machine.
> >>> ~Benjamin, K9LFZ
12 years later here, calling from the future; (in ASL3) radio-tune-menu fails with: Error parsing device parameters: No such command ‘radio-tune-menu-support 0+9’ (type core show help radio tune’ for other possible commands
But that gives a ‘Not found’ error.
The command IS there in /usr/sbin owned by root, and r and x-able.
Wassup? Tnx.
Bob
KK6RQ
EDIT: Nevermind; I don’t know if I fat fingered it or what but somehow USBradio came unconfigured; As soon as I reselected it everything started working again.
