Simple problem. Sorry for asking. It’s probably somewhere and I can’t find it. I want to go to the CLI and then do radio tune settings but I have three usb interfaces to radios. How do I specify which interface I am tuning when issuing the radio tune xxx command? Thx. Ve7nz
what you want to do is go to the command line (not the asterisk CLI) and use one of the menu programs depending which channel driver you are using:
simpleusb-tune-menu
radio-tune-menu
the first menu item is where you select which of the usb interfaces you are adjusting.
Ken
