I have a new R1-2023 audio board between a Dell Wyse 3040 and a pair of Retevis RT-85 HTs. When I transmit from another HT the audio is received OK by the RX HT and is heard in iaxrpt running on my home computer. It sounds good. Also while I am transmitting, the RED light on the R1-2023 is ON indicating that it is also transmitting to the TX HT, but the TX HT is not lighting up, and nothing is heard on that frequency from another HT. I am attempting to create the ANF101 full-duplex node that NR9V created. Any help in how to troubleshoot this TX issue would be appreciated. It is currently using USBRadio. Thanks de KR5EEE.
I would think the first step is to check your logic on the ptt line.
First know what is the correct logic. Most ptt’s float and switch to ground when active.
Then see what the line s line doing.
You may need to invert the ptt logic in simpleusb/usbradio .conf.
Past that, be sure you are using the correct ‘duplexmode=’
Sorry to necro, have you ever got around to fixing this? I actually have the anf101 duplex board from allscan but I’m running into this exact same issue.
Update: Fixed! Reached out to David over at AllScan and he advised the HTs must be mounted to the board for it to work. Initially I had the HTs running off the OEM battery. After getting the HTs mounted everything is running very smoothly.
