Those that want to homebrew can… Those that don’t want to; can buy it ready made!
Some of us like to engineer and build, troubleshoot and use. Others who’s time is more valuable or limited, just buy
what they need.
This is why my HF linear amplifiers are home brew! On the other hand… I also have a Nano Node. Go figure.
Sent: Tuesday, October 13, 2015 6:48 AM
To: Bryan D. Boyle ; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Quick sound fob question
I am with you Bryan.
But we don’t need to be rough on the OP.
I on my side prefer to have something like a URI on a production repeater cause if there is a problem, I don’t want to search hi and low for a cold solder joint on a pin the size on fly dick. (well they look that small for me ![Clignement d'œil]()
It must be because I worked on servicing high level security system and doing system integration that I think like that… the money is more then well spent for the simple reason that when something goes crazy, you don’t want more things to look at then you need.
Pierre VE2PF
Sent: Tuesday, October 13, 2015 9:28 AM
To: app_rpt-users@ohnosec.org
Why?
One is made as a generic part meant to be sold by the millions and assembled by workers making a couple cents an hour requiring time and effort on your part to modify and the other was designed to do a specific job and sold in relatively few numbers for a specific purpose.
I’ve never has an issue with a DMK dongle-- they just work. Way past the thrill of spending time modifying parts to do what it wasn’t designed to do to save a few bucks. My time is worth more than $60 or $70 an hour and would rather spend it actually tweaking the system than getting it to run in the first place.
And I have no financial interest in DMK or anything else around this system.
Bryan
On Oct 13, 2015, at 08:44, Skyler F electricity440@gmail.com wrote:
Oh. Well thanks for the replies. I don’t see how the URI is 25 times more expensive than the sound fob.
On Tue, Oct 13, 2015 at 6:36 AM, Steve Zingman szingman@msgstor.com wrote:
That is the Mute LED. If you mute the CM108 there may be no audio.
On 10/13/2015 8:25 AM, Skyler Fennell wrote:
To the pin with the red LED
On Oct 13, 2015, at 6:23 AM, Steve Zingman szingman@msgstor.com wrote:
Where do you want to switch it to?
On 10/13/2015 8:08 AM, Skyler Fennell wrote:
Ok, I’ll just solder the pin, just making sure.
It's weird you can't switch the gpio pin for PTT in software.
On Oct 12, 2015, at 11:54 PM, larry <larry@n7fm.com > wrote:
Skyler, Short answer is No!
My experience with the sound fobs that look similar to yours , You will still need to solder to Pin 13 to get the PTT logic. No way around that as on the CM-108 chip Pin 13 is not connected to anything so no place else to get that logic other than soldering a wire to the pin.
As for the COS signal (CM-108 Pin 48) that can be gotten from the left side of the volume down switch SW1 if you want to avoid soldering the COS line to Pin 48 on the sound chip. CTCSS can be retrieved from the right side of volume up SW2
The Green LED is still the heartbeat indicator.
The Red Led on the Fob is NOT the same as the PTT LED indicated on the modification schematic.
In fact if you go here http://www.crompton.com/hamradio/usb_fob_modification/
You will find a good description of the connections on that particular fob.
Larry - N7FM
On 10/12/2015 06:23 PM, Skyler Fennell wrote:
I previously got the CM108 sound fob from startech and had to solder to the tiny pin.
With this one [http://ebay.com/itm/291156304476?_mwBanner=1&varId=590306532025](http://ebay.com/itm/291156304476?_mwBanner=1&varId=590306532025)
It looks like it already has both LED's installed. I am assuming the red led is the same as the transmit LED.
If this is so, does that mean I don't have to solder to the tiny pin on the CM108 and I can just drive a transistor with the same wire as the LED for PTT?
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
To unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
