What you are saying makes sense, after narrowing down the edits to the two files sip.conf and extensions.conf I got a working system…
However it isn’t working 100%. No Node ID info is being sent or read and at best it is very annoying…since it announces N-O-C-I-D…
I attempted about 10 different solutions for the NO-CID node… including this attached one…but nothing changes.
Again, the setup is I am using my primary node number in all instances as required, and I am not running a PBX or Asterisk server outside the Allstar install.
Mike
