Question
I have a couple of people coming in and linking up while I am testing. Is there a way to forcibly disconnect the link without having to reboot the system. The link commands for COP or disconnecting all do not seem to work.
Any help in troubleshooting would be greatly appreciated.
73, Greg W2GCM
-----Original Message-----
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of app_rpt-users-request@ohnosec.org
Sent: Saturday, January 23, 2016 3:46 PM
To: app_rpt-users@ohnosec.org
Subject: App_rpt-users Digest, Vol 83, Issue 37
Send App_rpt-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
  ohnosec.org
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  app_rpt-users-owner@ohnosec.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of App_rpt-users digest..."
Today's Topics:
   1. Re: proxy registraltion (Bryan D. Boyle)
   2. Re: proxy registraltion (Steve Zingman)
   3. Re: proxy registraltion (Bryan D. Boyle)
Message: 1
Date: Sat, 23 Jan 2016 13:42:45 -0500
Subject: Re: [App_rpt-users] proxy registraltion
Message-ID: <F6D0182B-9938-4225-8724-4267BEA28CE7@bdboyle.com>
Content-Type: text/plain; charset="us-ascii"
read the proxy docs that scott referenced on ohnosec; I'm pretty much doing EXACTLY what it says there. I've a Pi, running DIAL , connected via a wifi dongle plugged into the Pi into an LTE hotspot, which I can throw in my car along with the radios and duplexer and have a mobile repeater with full allstar capabilities. The reason the proxy, it seems, exists is that the LTE IP address is a fungible/transient thing, which allstar doesn't handle very well as you traverse across tower boundaries. So, in order to have a mobile node, you stand up a proxy, as Scott has done to handle a few of us hackers on our network, and configure alkstar to talk TO IT instead of directly to the mother ship of the allstar network.
I'm using an Official Node Assignment. It has registered with Allstarlink before. It's number is 42761. it shows up in the master node list, in my server listing, and in my allmon. It does NOT, however, show up in the active nodes listing, which means that, regardless of whether i can connect to it, according to allstar, it's not marked as active. My question revolves around how to get it to show up in the active nodes list when it registers via a proxy server. I can connect it, but it's hidden in the active node list, even though even my allmon instance sees it.
Bryan
Sent from my iPhone 6S...No electrons were harmed in the sending of this message.
On Jan 23, 2016, at 12:19, Stacy <kg7qin@arrl.net> wrote:
Sounds like you are asking if you can register with more than one system using the same node ID number.
If you look at your iax.conf file, you will see a line similar to:
register=<nodenumber>:<password>@site
<nodenumber> = your node number
<password> = your password
What you haven't told us is what node number you are registering as. Are you actually using your AllStar node number or are you using a private node number in the range of 1xxx?
I'm not sure how AppRpt will handle having a single node number registered on multple systems, although the underlying registration process is handled by asterisk and not AppRpt itself. It "should" work, but you never know until you try it out. You would just have to make sure that if you tried this, you aren't bringing in the same audio source from multiple channels (effectively bridging them), since the results would not be pretty -- especially if there are any delays.
You can setup multiple nodes with different node numbers and register to different systems.
Take a look here for more information:
http://ohnosec.org/drupal/node/49
-Stacy
On 01/22/2016 08:03 PM, Bryan D. Boyle wrote:
Have a quick question...I've built a DIAL node on a Pi and have (with some great help from Scott KB2EAR) successufully brought it up on an LTE hotspot via wifi, and am using his hub as a proxy, successfully registering (and working) through his hub.
I'm registering to his hub, not the allstarlink registry; so this means that, for whatever reason (assuming because I don't touch the registry...but wouldn't the proxy do that?) I don't show up in the active nodes list.
If this is correct, and assuming you can't register to more than one registry (is that redundant?), is there a work around that would let me proxy my connection, but still also show me as active in the allstar database?
Does this make sense (I'm building out a portable repeater, but want
to have a full asterisk instance running rather than an RTCM
solution, and the Pi, couple GM300s, URI, and mobile duplexer makes
for a nice portable node. Not to mention that if I take the Pi, URI,
and hotspot sans radios, I built a speaker amp & Mic interface that
plugs into the URI that gives me asterisk connectivity without the
radios...in a hotel room or some such...)
Just throwing this out there...TIA.
Bryan
ohnosec.org
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
-------------- next part --------------
An HTML attachment was scrubbed...
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160123/a873a055/attachment-0001.html&gt;
Message: 2
Date: Sat, 23 Jan 2016 13:53:23 -0500
To: "Bryan D. Boyle" <bdboyle@bdboyle.com>
Cc: app_rpt-users@ohnosec.org
Message-ID: <-1914846469090443048@unknownmsgid>
Content-Type: text/plain; charset="utf-8"
Did you try a second register line in iax.conf?
Sent via smoke signal (Verizon)
Bryan
-Stacy
Does this make sense (I'm building out a portable repeater, but want to have a full asterisk instance running rather than an RTCM solution, and the Pi, couple GM300s, URI, and mobile duplexer makes for a nice portable node. Not to mention that if I take the Pi, URI, and hotspot sans radios, I built a speaker amp & Mic interface that plugs into the URI that gives me asterisk connectivity without the radios...in a hotel room or some such...)
Bryan
listApp_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
confirmation. If you have trouble unsubscribing, please send a message
to the list detailing the problem.
URL: <ohnosec.org - ohnosec Resources and Information.;
Message: 3
Date: Sat, 23 Jan 2016 15:45:28 -0500
To: Steve Zingman <szingman@msgstor.com>
Message-ID: <0A85E18D-F8B4-4973-BCCB-EC746F9173AE@bdboyle.com>
had thought of that...but was wondering what the implication would be of allstar seeing the same node number being registeredfrom two different IP addresses.
Bryan
Bryan
-Stacy
Bryan
ohnosec.org
ohnosec.org
URL: <http://ohnosec.org/pipermail/app_rpt-users/attachments/20160123/74561913/attachment.html&gt;
End of App_rpt-users Digest, Vol 83, Issue 37
*71 should be the command to disconnect all.
See "NOICE" command to stop incoming connects using control states stanza profiles.
NO Incoming Connection Enable.
http://ohnosec.org/drupal/node/166
...mike/kb8jnm
73, Greg W2GCM
