Proxy Server and Echolink
Node 2186 is set up with a proxy and seems to be working perfectly for incoming and outgoing Allstar calls. However, I’m having trouble with Echolink. The station list appears to be downloading, my node shows up in the Echolink active node list, but I have trouble connecting to other Echolink nodes including the Echo Reflector. Sometimes when I do manage to connect, I will be disconnected within a few minutes. Should Echolink work normally with a proxy server or have I perhaps fat-fingered something in the config files?
Troubleshooting suggestions appreciated.
John
