Your question is very cryptic…
I dont understand exactly what is your situation…
Do you connect to Scott node as a private node then can hear what is happening on what is conncted to his node?
do you connect to his network by vpn then try to connect to the allstarlink network?
I never heard of proxy for voip. And if that is what you use I am sure that you need to have different port number for the IAX connection to happen for 2 node.
Same with VPN, once you connect to his network by VPN the rest of the insternet see you as being beind the VPN network router, so your node and his will be at the same IP adress for the rest of the world.
I know that allstar will use the public adress from wich a node connect to report back to the other node where it is… But if 2 node report from the same adress they need to be on different port (4569 is the default)
please be bit more specific about the proxy thing…
Pierre
VE2PF
Date: Fri, 22 Jan 2016 23:03:39 -0500
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] proxy registraltion
Have a quick question…I’ve built a DIAL node on a Pi and have (with some great help from Scott KB2EAR) successufully brought it up on an LTE hotspot via wifi, and am using his hub as a proxy, successfully registering (and working) through his hub.
I’m registering to his hub, not the allstarlink registry; so this means that, for whatever reason (assuming because I don’t touch the registry…but wouldn’t the proxy do that?) I don’t show up in the active nodes list.
If this is correct, and assuming you can’t register to more than one registry (is that redundant?), is there a work around that would let me proxy my connection, but still also show me as active in the allstar database?
Does this make sense (I’m building out a portable repeater, but want to have a full asterisk instance running rather than an RTCM solution, and the Pi, couple GM300s, URI, and mobile duplexer makes for a nice portable node. Not to mention that if I take the Pi, URI, and hotspot sans radios, I built a speaker amp & Mic interface that plugs into the URI that gives me asterisk connectivity without the radios…in a hotel room or some such…)
Just throwing this out there…TIA.
Bryan
