Steve,
Iâm not sure what you are referring to as ânew versionâ,
but allmon2 has always used the asterisk manager to access to node data from in/outside the OS via www.
So, you still need to follow the directions for allmon2 in setting a password to protect the install directory for web login purposes⌠That part is not the same as the following.
Steve â I forgot to add the username stanza in the version you have. As Mike said, you can just add something like this to the end of manager.conf OR create a new file in manager.d such as âadmin.confâ:
btw, I did not know about this change. Thatâs why is ALWAYS a really good idea to post your questions here rather than sending me an email⌠because. believe it or not, I donât know everything.
Is anyone getting issues with the R-Pi 4 and Allmon2
Iâm using the http interface. and When I try to log in It fail, additionally when I select my node number
it is not showing any telemetry or connection data. and states âXXXXXâ Node is not in Database
What am i missing.
If you have an existing Allmon2 installation, you can copy the allmon.ini.php from that and try from there. Make sure you set the manager password in there.
