Problems surrounding Dial with service asterisk stop and start along with restart
Greetings I have found an issue today on a pure dial install out in a Data Center environment where service asterisk stop and service asterisk start did not work… Anyone else having these issues with Dial?
Here is some other commands i tried instead…
root@hub:/etc/init.d# ./asterisk status
● asterisk.service - LSB: Asterisk PBX
Loaded: loaded (/etc/init.d/asterisk)
Active: failed (Result: exit-code) since Wed 2016-08-31 05:56:34 EDT; 22min ago
Process: 19146 ExecStop=/etc/init.d/asterisk stop (code=exited, status=0/SUCCESS)
Process: 19289 ExecStart=/etc/init.d/asterisk start (code=exited, status=1/FAILURE)
Aug 31 05:56:34 hub.kc9zhv.com asterisk[19289]: Asterisk is already running. /etc/init.d/…w.
Aug 31 05:56:34 hub.kc9zhv.com systemd[1]: asterisk.service: control process exited, code…s=1
Aug 31 05:56:34 hub.kc9zhv.com systemd[1]: Failed to start LSB: Asterisk PBX.
Aug 31 05:56:34 hub.kc9zhv.com systemd[1]: Unit asterisk.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
root@hub:/etc/init.d# ./asterisk forcestart
Usage: /etc/init.d/asterisk {start|stop|restart|reload|force-reload}
root@hub:/etc/init.d# ./asterisk force-reload
[…] Reloading asterisk configuration (via systemctl): asterisk.serviceJob for asterisk.service failed. See ‘systemctl status asterisk.service’ and ‘journalctl -xn’ for details.
failed!
root@hub:/etc/init.d# ./asterisk reload
failed!
As you see above i still received failures to stop and start asterisk using even this method
Any thoughts?
Anyone had any luck porting any of this to centos 7?
Considering making it part of a nethserver project i have been working on…
Loren Tedford (KC9ZHV)
Phone:
Fax:
Email: lorentedford@gmail.com
Email: KC9ZHV@KC9ZHV.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://forum.kc9zhv.com
http://hub.kc9zhv.com
http://Ltcraft.net
http://voipham.com
Loren,
Yes it's a known issue. There is a problem with the init scripts.
The next version uses systemd. If you want to convert to systemd now
see Careful reading of the README.md may yield another solution.
73, Steve N4IRS
https://github.com/N4IRS/AllStar/tree/master/systemd
  On 08/31/2016 06:24 AM, Loren Tedford
./asterisk status
/etc/init.d/…w.
code…s=1
        [....] Reloading asterisk configuration (via systemctl):
details.
failed!
./asterisk reload
details.
failed!
Any thoughts?
been working on…
                Loren
Tedford (KC9ZHV)
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
1st Law of Logic
root@hub:/etc/init.d#root@hub:/etc/init.d#root@hub:/etc/init.d#root@hub:/etc/init.d#root@hub:/etc/init.d#App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
