Problem with Allmon3 on new ASL3 Cloud install
After new install with ASL3 Cloud install. I installed and setup allmon3 per the manual.
When I run webserver is comes back with (529343 - Unavailable Node).
I can login into allmon3 just fine.
I am not sure what I missed. Allmon3 is not seeing ALS3 server 529343.
Mar 22 23:13:25 als3-hub-server allmon3[953]: ERROR: (asl_allmon.ami_conn) Logon failure msg=(Response: Error Message: Authentication failed )
Mar 22 23:13:25 als3-hub-server allmon3[953]: ERROR: (asl_allmon.allmon3_ws_status) No connection for 127.0.0.1:5038 on 16700 due to unreachable AMI - waiting 15 seconds
Installed onDebian 13
Tom
WM0L
I found my problem. I did not get the AMI password copied correctly to allmon3.ini file…
