Problem with a Two Node Configuration.
Hi All
A colleague – VA3SD – built a standalone node on an Acid based platform, the node he was assigned is 27211. The associated callsign is VE3UOR.
WE needed to add a second node, so I subscribed and was given node number 29133. The repeater callsign is VE3LSR and my profile is established as VA3YC.
I followed the guidance from the internet regarding the creation of two nodes on the same ACID platform.
The resulting configuration more or less works. Here are the issues I am seeing:
  1. Both nodes show up on the nodelist page. You can do a successful drill down on detail for the VE3LSR/29133 node, but it is not possible on the VE3UOR/27211 node.
  2. You can successfully connect from the VE3UOR node to the VE3LSR node but not vice versa.
Thoughts or guidance will be much appreciated.
Keith
keith@goobie.org
Keith Goobie
Richmond Hill, ON, CANADA
Hi,
OK, so both nodes are on the same machine. Are they both on separate URI's or other USB interfaces, or is one used for something else?
A couple things spring to mind:
First, in your rpt.conf file, do you have lines in both to report status?
Second, you're going to need both nodes defined locally as 127.0-.0.1. Mine looks like this, so just replace your node numbers:
[nodes]
2331 = radio@127.0.0.1/2331,NONE
28529 = radio@127.0.0.1/28529,NONE
Betcha a cold cheeseburger that only one of these is defined, i.e. the one you can connect to.
Buddy Brannan, KB5ELV - Erie, PA
Phone: (814) 860-3194 or 888-75-BUDDY
On Nov 23, 2012, at 9:11 AM, Keith Goobie <keith@goobie.org> wrote:
Hi All
  • Both nodes show up on the nodelist page. You can do a successful drill down on detail for the VE3LSR/29133 node, but it is not possible on the VE3UOR/27211 node.
  • You can successfully connect from the VE3UOR node to the VE3LSR node but not vice versa.
Keith
keith@goobie.org
Keith Goobie
ohnosec.org
Hi Keith:
Sorry got tied up last night!
You need to add the extension to the dialplan in extensions.conf
From what I remember, I think you had this covered - but will take a closer look later (at the mall shopping right now!).
Ramesh.
Sent on the TELUS Mobility network with BlackBerry
-----Original Message-----
Sender: app_rpt-users-bounces@ohnosec.org
Date: Fri, 23 Nov 2012 09:11:54
To: <App_rpt-users@ohnosec.org>
Subject: [App_rpt-users] Problem with a Two Node Configuration.
I believe Buddy is on the right track.
In the Rpt conf there is these 2 lines that should be uncommented:
; ** For ACID ***
statpost_program=/usr/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null ; Get the node list for this box - only needs to stated once.
statpost_url=http://stats.allstarlink.org/uhandler.php ; This sends the status to the Allstar server for this node where this line is located in its node stanza.
If you have 2 nodes, then the above line also needs to be in the second node stanza to report its stats to the Allstar website.
I see that UOR 27211 is not reporting to the Stats page.
If it doesnt show up there, no node can connect to it.
Jon VA3RQ
On 11/23/2012 9:37 AM, Buddy Brannan wrote:
Hi,
[nodes]
On Nov 23, 2012, at 9:11 AM, Keith Goobie<keith@goobie.org> wrote:
Hi All
A colleague � VA3SD � built a standalone node on an Acid based platform, the node he was assigned is 27211. The associated callsign is VE3UOR.
  � Both nodes show up on the nodelist page. You can do a successful drill down on detail for the VE3LSR/29133 node, but it is not possible on the VE3UOR/27211 node.
  � You can successfully connect from the VE3UOR node to the VE3LSR node but not vice versa.
Keith
keith@goobie.org
Keith Goobie
ohnosec.org
ohnosec.org
Good day Buddy and thanks for the response.
Yes, both nodes are on the same machine. There are two URI on that same
machine, one dedicated to each node.
Regarding the reporting of status - your comment provoked me to look in the
right area and voila it works.
I also was shy in the second node that needed to be identified in [nodes]
corrected, now to test.
Keith
On 11/23/12 9:37 AM, "Buddy Brannan" <buddy@brannan.name> wrote:
Hi,
[nodes]
can connect to.
Hi All
A colleague ­ VA3SD ­ built a standalone node on an Acid based platform, the
VA3YC.
seeing:
€ Both nodes show up on the nodelist page. You can do a successful drill
VE3UOR/27211 node.
€ You can successfully connect from the VE3UOR node to the VE3LSR node but
not vice versa.
Keith
keith@goobie.org
Keith Goobie
ohnosec.org
keith@goobie.org
Keith Goobie
Reporting now sorted.
Keith
; ** For ACID ***
v/null
Jon VA3RQ
Hi,
[nodes]
you can connect to.
Hi All
VA3YC.
seeing:
VE3UOR/27211 node.
not vice versa.
Keith
keith@goobie.org
Keith Goobie
ohnosec.org
ohnosec.org
ohnosec.org
keith@goobie.org
Keith Goobie
