I have two servers with a node on each one. The first one is a clearnode that works fine. I am trying to add a second radioless node with a Pi5 and and UCI150. I have verified the UCI150 works on QSO One and another WT app. My first node is IAX 4569, and I have bumped the IAX address to 4570 and openned up the port on my router. My broadband provider is Spectrum. Here is the error message.
asl@node667431:~ $ sudo asl-node-auth-check
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: rpt.conf has configuration for: 667431
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 667431
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 75.114.185.71
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 75.114.185.71
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 75.114.185.71
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 75.114.185.71
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 75.114.185.71
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 75.114.185.71
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 667431:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
Error: register.allstarlink.org is unreachable (via HTTP)
Error: HTTP registration state is Not Registered
Info: Stopping node checks due to registration failure
Info: as further information will be unreliable
Michael - KF8EBV
Error: Node 667431 has 1 error(s)!
