Private Nodes
I'm trying to understand private nodes, and building one for test. I have
some questions.
Once I setup a private node, can it link with an Allstar node? If so, how?
If I wanted to link it to an Allstar node, would I need to make a connection
in the [nodes] stanza that points to the Allstar node. Or perhaps setup a
private node on a second server with an Allstar node, that can see its
associated private node, then permanently link the two servers together
using the two private nodes?
Perhaps the broader question is what functionality can be realized with a
private node other than permanently hosted to an Allstar node?
Bob
kk6ecm
The advantage I see to a private node is to provide a "service" to your nodes. That could be EchoLink, DMRGateway or Remote Base to name a few. You can connect or disconnect as needed from your public node. For me, when I had a EchoLink connected node, I could disconnect my public node and not hear all the "Drive By" connects.
Steve
some questions.
Bob
kk6ecm
"Anything is possible if you don't know what you are talking about."
1st Law of Logic
See comment below...
some questions.
Yes and no. With a standard config, no it cannot connect to public nodes. But if both the private node and the public node are configured then yes these two nodes can connect to each other. Generally private nodes cannot connect to any public nodes without modifying the public nodes to accent that private nodes.
If so, how?
Public nodes use the Allstar server as an IP lockup. However private nodes (node numbers below 2000) cant use this service. So connecting private nodes requires the IP of each node to be defined in the NODES stanza in rpt.conf.
So if you had node 1234 and wanted to connect to 1235, the nodes stanza of 1234 must have the ip of node 1235 defined and in node 1235 must have the ip of node 1234 defined. Then the two nodes can connect. This is true if both noes are on different servers or in the same box.
The same applies between a private node and a public node, the public node must have the IP of the private node defined in its nodes stanza and vice versa. Once the two nodes are aware of each other, the connection can be made.
Private node can be used to make connections on link systems that are "off the grid" or replace an dedicated RF link.
They can also be used as Steve suggested as a "accessory" connection to a public node to allow cross connections to be patched in or out with ease.
Bob
kk6ecm
Jon VA3RQ
Thanks all... I have a bit to digest here :slight_smile:
Thanks much,
Bob
kk6ecm
Sent from iPad
some questions.
If so, how?
Bob
kk6ecm
Jon VA3RQ
