private nodes with dynamic IP
Hi all,
I am a new app_rpt user, I have a server with installed ACID, server have static IP. I have 3 assembled RTCM boards configured as voting repeater, it works fine.
One RTCM can work as simplex node too.
I was compiled app_rpt for Raspberry pi with SimpleUSB, it works, but I have question:
How I can connect 2 maybe 3 or more) PC based „slave“ nodes (endnodes with radio connected) to „master“ server, if only „master“ server have a static IP, and all endnodes use dynamic?
Two nodes in local network with static IP works fine
All my nodes a private system(s), not in Allstar network. Master server have static IP, and all endnodes (PC based and RTCMs have dynamic addresses)
Thanks!
Mihhail Jakovlev
ES1BIS
Tell us more about that. You might be the first one to get this working that I know of. What did you do to get it going? If you could document what you did and possibly supply an image that would be great.
73 Doug
WA3DSP
To: app_rpt-users@ohnosec.org
Date: Sat, 15 Feb 2014 22:08:01 +0000
Subject: [App_rpt-users] private nodes with dynamic IP
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
Just about to setup a single node beaglebone black
Got ubuntu 12 loaded now have the fun of getting arm to compile but there are raspbx (ast 11) compiles out there so should not be too bad.
Sent from my Verizon Wireless BlackBerry
-----Original Message-----
Sender: app_rpt-users-bounces@ohnosec.org
Date: Sat, 15 Feb 2014 22:18:48
To: Mihhail Jakovlev<mihhail.jakovlev@telegrupp.ee>
Cc: app_rpt-users@ohnosec.org<app_rpt-users@ohnosec.org>
Subject: Re: [App_rpt-users] private nodes with dynamic IP
Put the static IP address for the central node in the remote rpt.conf’s they all call themselves 127.0.0.1. Have them all initiate connections to the central node. I think that should work. I don’t think the central node needs the remote IP addresses if it isn’t calling to them.
I think.
I have to try that some time.
5 minutes later
OK, I tried this on my remote node. The “central node” has an incorrect IP address for the remote node. The remote node has the correct IP address for the central node in its rpt.conf file. I commanded the remote node to connect to the central node, worked fine. That scheme should work for you. Assume 1999 is central node and 1998 is remote. In central 1999 rpt.conf: 1998 = radio@192.168.xxx.yyy:4569/1998,NONE Then in remote 1998 rpt.conf: 1999 = radio@rea.lip.add.res:4569/1999,NONE
“rpt reload” on each end and it should work.
GeorgeC
W2DB
2360
Sent: Saturday, February 15, 2014 4:08 PM
To: mailto:app_rpt-users@ohnosec.org
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
Thanks, I try it soon and see what relult is
Mihhail Jakovlev
[mailto:george@dyb.com]
Sent: Sunday, February 16, 2014 7:23 AM
To: Mihhail Jakovlev; app_rpt-users@ohnosec.org
I think.
5 minutes later
GeorgeC
W2DB
2360
Mihhail Jakovlev
Sent:
To:
Subject:
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
It was so simple, one problem only install kernel sources, without sources you cannot install DAHDI. I found how to install it on Fedora17.
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=17322&p=345763
Use 8GB SD card class 10 or better, original Raspi class 4 card is slow.
Put to card Fedora remix fc17.r2, it use kernel version 3.2.27. After this install sources as discribed in
Download and install last DAHDI
http://downloads.asterisk.org/pub/telephony/dahdi-linux/ and DAHDI tools.
Install all packages and development tools for Asterisk compiling. (from Asterisk README file, other shows Menuconfig, if any needed)
Download Asterisk from
http://svn.ohnosec.org/svn/projects/allstar/astsrc-1.4.23-pre/trunk/
Compile and install, it have no any problems. If compiler shows if any package not found, install package and rerun compilation
Replace default config files with downloaded from
http://svn.ohnosec.org/svn/projects/allstar/astsrc-1.4.23-pre/trunk/configs/
Configure you SimpleUSB. I use a CM108 SYBA card
http://www.amazon.com/gp/product/B001MSS6CS/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
And it works.
But Fedora is not a best system, Debian faster and Debian support Raspi CPU overlock to 1ghz, but I dont know, how to install kernel sources… If any help…
Mihhail Jakovlev
From: hotmail_97fc649978f54bf0@live.com [mailto:hotmail_97fc649978f54bf0@live.com]
On Behalf Of Doug Crompton
Sent: Sunday, February 16, 2014 5:19 AM
Subject: RE: [App_rpt-users] private nodes with dynamic IP
73 Doug
WA3DSP
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
_______________________________________________ App_rpt-users mailing list
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button” You do not
need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
Mihhail,
That is great. Very glad to hear you got this going. I will certainly be trying it. Are you happy with the performance in simpleusb? What is the load average?
73 Doug
WA3DSP
To: doug@crompton.com
CC: app_rpt-users@ohnosec.org
Date: Sun, 16 Feb 2014 09:45:48 +0000
And it works.
Mihhail Jakovlev
73 Doug
WA3DSP
Seems to me the biggest problem with this would be getting COS from somewhere? No parallel port. Guess you’d have to get the modifiable CM108-based cards and wire for hardware COS? Or am I missing something important?
On Feb 16, 2014, at 10:43 AM, Doug Crompton <doug@crompton.com> wrote:
Mihhail,
73 Doug
WA3DSP
Put to card Fedora remix fc17.r2, it use kernel version 3.2.27. After this install sources as discribed in http://www.raspberrypi.org/phpBB3/viewtopic.php?t=17322&p=345763
Download and install last DAHDI Index of /pub/telephony/dahdi-linux/ and DAHDI tools.
  Download Asterisk from http://svn.ohnosec.org/svn/projects/allstar/astsrc-1.4.23-pre/trunk/
Replace default config files with downloaded from ohnosec.org
Configure you SimpleUSB. I use a CM108 SYBA card http://www.amazon.com/gp/product/B001MSS6CS/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
And it works.
But Fedora is not a best system, Debian faster and Debian support Raspi CPU overlock to 1ghz, but I dont know, how to install kernel sources... If any help...
Mihhail Jakovlev
From: hotmail_97fc649978f54bf0@live.com [mailto:hotmail_97fc649978f54bf0@live.com] On Behalf Of Doug Crompton
73 Doug
WA3DSP
ohnosec.org
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
The cheapie FOBs modified or the DMK URI as is work USB. No other ports needed. This is true with any hardware.
73 Doug
WA3DSP
Date: Sun, 16 Feb 2014 11:01:32 -0500
On Feb 16, 2014, at 10:43 AM, Doug Crompton doug@crompton.com wrote:
Mihhail,
73 Doug
WA3DSP
And it works.
Mihhail Jakovlev
73 Doug
WA3DSP
ohnosec.org
ohnosec.org
Mihhail,
I forgot to mention. Debian is a problem with the older Asterisk code which app_rpt requires. Since you used Fedora you overcame that problem. The overclocking is a hardware issue. Perhaps there is a Fedora/Pi forum where you can ask that question.
73 Doug
WA3DSP
And it works.
Mihhail Jakovlev
73 Doug
WA3DSP
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
But if i create „virtual“ local node 2198 in central server and in remote node 1998 create a startup macro *32198, I have automatic permanent connection between 1998 and 2198. And if I call from any other node
to 1998, I have connection established? (central server know, where is 1998, because it is connected to local node 2198).
Tervitades,
Mihhail Jakovlev
I think.
5 minutes later
GeorgeC
W2DB
2360
Mihhail Jakovlev
Sent:
To:
Subject:
Hi all,
Thanks!
Mihhail Jakovlev
ES1BIS
