Private node linking
I have two Rasp pi 4. They set up for private. I would like to be able to have one pi on the repeater and one on a simplex radio to link from one repeater to the other. There is NO internet at one site. How do I set up node A 1976 t repeater to connect to Node B. 1977. When either the repeater or simplex radio is keyed, both nodes need to key. I am sure this is simple, but I am missing something. Here is what I have done. Nothing else yet. This is my first attempt going this deep with Allstar.
[1976] ; Change this to your assigned node number
; CHANNEL DRIVER SETTINGS
; Define a channel driver to use and which
; interface within that channel driver
; To define a radioless node use the
; psuedo channel driver - rxchannel=dahdi/pseudo
;rxchannel=Radio/usb1976
; Example usbradio channel driver
rxchannel=SimpleUSB/usb
; Example simpleusb channel driver
;rxchannel=dahdi/pseudo
; Example pseudo channel driver
;rxchannel=iopipe/stanza1
; Future hamvoip IOpipe channel driver
; stanza1 rename to actual stanza name in iopipe.conf file
;txchannel=
; The txchannel allows separate sound cards for the
; receive and transmit audio paths. This is seldom used
; but shown here to make the user aware of its existence.
; It would take the same parameters as rxchannel.
; NODE LOOKUP METHODS
			; There are three choices for the way to lookup
			; nodes. Being able to lookup nodes and mapping
			; to an IP address and port is a requirement
			; for proper operation of Allstar.
			; NOTE - when using DNS lookup on all nodes on
			; a server the filelookup_onoff.sh script should
			; be used to turn off redundant flat file lookups.
			; DNS lookup is the default.
			; node_lookup_method=dns  (Default)
			;   Uses hamvoip DNS lookup
			; node_lookup_method=file
			;   Uses Allstar flat file lookup
			;   Deprecated in hamvoip v1.5
			; node_lookup_method=local
			;   Uses local fixed routing defined in the
			;   [nodes] stanza below
; REPEATER/SIMPLEX NODE SETTINGS
; duplex=0 - Half duplex with no telemetry
; tones or hang time. Special Case: Full
; duplex if linktolink is set to yes.
; This mode is preferred when interfacing
; with an external multiport repeater controller.
			; duplex=1 - Half duplex with telemetry tones
			; and hang time. Does not repeat audio.
			; This mode is preferred when interfacing a
			; simplex node. This is the default mode.
			; duplex=2 - Full Duplex with telemetry tones
			; and hang time. This mode is preferred when
			; interfacing a repeater.
			; duplex=3 - Full Duplex with telemetry tones
 			; and hang time, but no repeated audio. Often
			; used for radio-less nodes.
			; duplex=4 - Full Duplex with telemetry tones
			; and hang time. Repeated audio only when the
			; autopatch is down.
duplex=2
; CONTEXT MAPPING
controlstates=controlstates1976
; Defines groups of control operator commands
; to be executed all at once. Can be combined
; with macros to allow changes to a nodes
; operating mode to be made quickly.
scheduler=schedule1976
; Defines macros to be executed at a specific
; time and date. Uses a cron-like syntax
morse=morse1976
; Contains definitions for morse code messages.
; One common morse stanza is shared across
; multiple nodes
macro=macro1976
; Defines DTMF macro sequences
functions=functions1976
; Defines DTMF function digit sequences. A
; function stanza has a reference to it defined
; inside a node stanza. Multiple function stanzas
; may be defined and used to provide different
; function lists for different sources
; (radio.phone, and link)
phone_functions=functions1976
link_functions=functions1976
telemetry=telemetry1976
; Contains definitions for telemetry tones
; (courtesy tones, roger beeps, etc). A telemetry
; stanza has a reference to it defined inside
; a node stanza.
wait_times=wait-times1976
; Contains time delays used to time audio
; telemetry events
events=events1976
; Allstar events
; ECHOLINK SETTINGS
; Echolink is a separate module.
; The Echolink.conf file must be
; configured for it to function
erxgain=-3
; Echoline RX gain in dB
etxgain=3
; Echolink TX gain in dB
;eannmode=1
; Echolink announcement mode
; Default: 1 = Say only node number on echolink
; connects. 2 = say phonetic call sign only on
; echolink connects. 3 = say phonetic call sign
; and node number on echolink connects
; IRLP SETTINGS
; IRLP is a separate hamvoip package which must
; be installed and configured for it to be
; functional.
irxgain=-6
; IRLP receive gain adjustment
itxgain=4
; IRLP transmit gain adjustment
irlpann=0
; Default: 1 = Play irlp connect and disconnect
; announcements
; 0 = Disable irlp connect and disconnect
; announcements
; AUDIO LEVEL SETTINGS IN dB
telemnomdb=0
; Overall reduction in telemetry level
telemduckdb=-9
; Telemetry level reduction with signal
; NOTCH FILTER
;rxnotch=1000,20
; Apply a notch to filter the RX signal. Values are:
; frequency, bandwidth. Up to ten filters can be cascaded.
; Example of three cascaded filters at 1000hz
; 20hz bandwidth: rxnotch=1000,20,1000,20,1000,20
; DIAL PLAN SETTINGS
context = radio
callerid = Repeater <000001976>
; This setting allows the autopatch on
; the node to be identified with a specific
; caller ID
accountcode=RADIO
; ID SETTINGS
; ID recording files must have extension gsm,ulaw,pcm,
; or wav. No file extension is used.
; All ID recording files should be sampled at 8KH
;idrecording=/etc/asterisk/local/node-id
; Main ID voice
;idrecording=|iDE WB7TJD/L
; Main ID CW
;idtalkover=|iDE WB7TJD/L
; ID when signal present
; TIME SETTINGS - milliseconds
; The default values for hangtime, tx_timeout,
; and id interval time are ; 5 seconds (5000 ms),
; 3 minutes (180000 ms), and 5 minutes (300000 ms)
; respectively
hangtime=100
; squelch tail hang time (in ms)
althangtime=100
; This controls the length of the node hang time
; when the alternate hang timer is selected with
; a control operator function.
tx_timeout=240000
; changed from totime V1.3
idtime=600000
; ID every 10 minutes
politeid=30000
; The politeid setting specified the number of
; milliseconds prior to the end of the id cycle
; where the controller will attempt to play the
; ID in the tail when a user unkeys. If the
; controller does not get a chance to send the
; ID in the tail, the ID will be played over
; the top of the user transmission.
rx_timeout=300000
; Timeout on hardware COS. Used to avoid hangup
; of circuits with COS lockup.
rx_cosflap=20
; Minimum COS Timeout reset period. Used to
; avoid resseting of rx_timeout with a flapping
; squelch.
; COURTESY TONE MAPPING
unlinkedct=ct2
; Sent when not connected to another node
remotect=ct3
; Sent when remote base connected
			; The linkunkeyct command can be used to
			; customize the courtesy tone based on
			; a node number. This is useful to identify
			; input from a specific node. See the
			; howto at hamvoip.org for details.
linkunkeyct=ct8
; sent when a network user unkeys. This
; method uses the mapped tone for all nodes.
;linkunkeyct=by_node_number,ct8
; Use this method to send a distinct courtesy
; tone based on node number. If node number is
; not defined use the default tone shown here
; as ct8. Comment the linkunkeyct=ct8 above
; when using this method. See the howto on this
; at hamvoip.org for additional information.
;node40000=ct12
; Define node number to mapped tone for
; distinctive courtesy tone. Multiple nodes
; can be mapped to multiple mappings by adding
; additional nodexxxxx=ctxx lines. ctxx tones
; must be defined in the [telemetry] stanza
; LINK SETTINGS - values in seconds
;nolocallinkct=0
; Send unlinkedct instead of linkedct if
; another local node is connected to this
; node (hosted on the same server).
;lnkactenable=0
; The link activity timer may be used to reset
; a link configuration back to a default
; configuration if a user changes how the node
; is linked. This helps in situations where the
; user forgets to reset the system to the default
; values, or drives out of range.
;lnkacttime=1800
; This sets the amount of time to wait before
; executing the inactivity macro. Set to a value
; between 180 and 2000000 seconds.
;lnkactmacro=*52
; This is the function to execute when the activity
; timer expires. This can either be a function or
; another macro defined in the [macros] stanza.
;lnkacttimerwarn=30seconds
; For a 30 second warning message, set this to the
; path of a ulaw or pcm sound file to play locally
; when there is 30 seconds left on the activity timer.
; Defualts to /var/lib/asterisk/sounds
; REMOTE SETTINGS - values in seconds
;remote_inact_timeout=1800
; Specifies the amount of time without keying
; from the link. Set to 0 to disable timeout.
;remote_timeout=3600
; Specifies the amount of time without keying from
; the link. Set to 0 to disable timeout.
; LONG TONE ZERO DTMF
; LiTZ is a simple method to indicate to others on
; an amateur VHF / UHF FM radio frequency that you
; have an immediate need to communicate with someone,
; anyone, regarding a priority situation or condition.
; This command can call any DTMF function which could
; then call a script or program. It does not have to
; use the autopatch.
;litzcmd=*6911
; Command sequnce – Call 911 on autopatch
;litztime=3000
; time required to hold down DTMF, defaults to 3000 ms
;litzchar=0
; DTMF character to activate LITZ, defauls to 0
; MISC. SETTINGS
parrot=0 ; One time parrot modr with DTMF A9
;connpgm=yourconnectprogram
; Program or script to run at connection
;connpgm=/usr/local/sbin/supermon/smlogger 1 ; use this line for Supermon
;discpgm=yourdisconnectprogram
; Program or script to run at disconnection
;discpgm=/usr/local/sbin/supermon/smlogger 0 ; use this line for Supermon
nounkeyct=0
; Disable courtest tones (=1)
holdofftelem=1
; Do not make announcements over user voice
telemdefault=2
; 0= voice telemetry off, 1= on,
; 2= Only your telemetry actions
; then mutes in 1 minute
beaconing=0
; When set to 1 will send the repeater ID at
; the idtime interval regardless of whether
; there was repeater activity or not.
;funcchar = *
; function lead-in character (defaults to ‘*’)
;endchar = #
; command mode end character (defaults to ‘#’)
;nobusyout=yes
; (optional) Do not busy-out reverse-patch when
; normal patch in use
;notelemtx = yes
; telemetry output does not make main
; system transmit (optional)
;propagate_dtmf = yes
; DTMF sent to system from link gets
; repeated onto main system output
;propagate_phonedtmf = yes
; DTMF sent to system from phone gets
; repeated into main system output and
; link outputs (optional)
linktolink = yes
; disables forcing physical half-duplex
; operation of main repeater while
; still keeping half-duplex semantics
;inxlat = #456,#457,0123456789ABCD
; translate digit strings inbound,
; in this case intrepret #456 as star,
; #457 as pound, and pass all the other
; chars listed in arg3 (optional)
;outxlat = *7,*0,0123456789#ABCD
; translate digit string outbound,
; in this case *7 generates star, *0
; generates pound, and all the other
; digits pass along
;extnodes = extnodes-different
; section in extnodefile containing
; dynamic node information (optional)
;extnodefile = different-file
; file containing dynamic node
; info (optional)
;archivedir = some-directory
; defines and enables activity recording
; into specified directory (optional)
;archiveaudio=0
; Disable saving audio files when
; archiving. Use with caution on SDcards
; This write a lot of data.
;archivetype=gsm
; Allows the selection of gsm (.wav) or
; pcm (.ul) for archiving audio files
startup_macro = *731977
; Macro to run at startup (optional)
startup_macro_delay=10
; Time in seconds to wait before executing
; the startup macro
; TAIL MESSAGE
; The tailmessagetime,tailsquashedtime, and tailmessages need to be set
; to support tail messages. They can be omitted otherwise.
;tailmessagetime=1800000
; Play a tail message every 5 mins
;tailsquashedtime=120000
; If squashed by another user,
; try again after 30 seconds
;tailmessagelist=/etc/asterisk/local/some_file
;list of messages to be played for tail message
; *** STATUS REPORTING ***
; Uncomment the following two statpost lines to report the
; status of your node to stats.allstarlink.org
;statpost_program=/etc/asterisk/local/send_node_stats.sh
;statpost_url=none
; END OF FIRST NODE
; BEGIN SECOND NODE
; Second node shown as a pseudo node
; This node can be edited to include a second public or private node
[1999] ; Change this to your assigned node number
;rxchannel=Radio/usb1999
;rxchannel=SimpleUSB/usb2
; Stanza for usb2 needs to be added to simpleusb…conf
;txchannel=
duplex=1
; CONTEXT MAPPING
morse=morse1976
; multiple nodes
macro=macro1976
; a node stanza.
; telemetry events
events=events1976
; Allstar events
; ECHOLINK SETTINGS
erxgain=-3
etxgain=3
;eannmode=1
; IRLP SETTINGS
; functional.
irxgain=-6
itxgain=4
irlpann=0
; announcements
; announcements
telemnomdb=0
telemduckdb=-9
; NOTCH FILTER
;rxnotch=1000,20
context = radio
; caller ID
accountcode=RADIO
; ID SETTINGS
; Main ID voice
; Main ID CW
; respectively
hangtime=100
althangtime=100
tx_timeout=240000
idtime=600000
politeid=30000
rx_timeout=300000
rx_cosflap=20
; squelch.
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
;node40000=ct12
;nolocallinkct=0
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
; Defaults to /var/lib/asterisk/sounds
;litzcmd=*6911
;litztime=3000
;litzchar=0
; MISC. SETTINGS
nounkeyct=0
holdofftelem=1
telemdefault=2
beaconing=0
;funcchar = *
;endchar = #
;nobusyout=yes
;notelemtx = yes
;linktolink = yes
; digits pass along
; info (optional)
;archiveaudio=0
; Disable saving .wav files when
;archivetype=gsm
; Allows the selection of gsm/wav or
; pcm/ulaw for archiving audio files
;startup_macro = *7
;startup_macro_delay=10
; the startup macro
; TAIL MESSAGE
;;;statpost_program=/etc/asterisk/local/send_node_stats.sh
;;;statpost_url=none
; END OF SECOND NODE
; MORSE CODE PARAMETERS
[morse1976]
speed=20
frequency=800
amplitude=4096
idfrequency=750
idamplitude=1024
; CONTROL STATES
[controlstates]
;statenum = copcmd,[copcmd]…
0 = rptena,lnkena,apena,totena,ufena,noicd ; Normal operation
1 = rptena,lnkdis,apdis,totena,ufdis,noice ; Repeater only operation
; SCHEDULES
[schedule1976]
;dtmf_function = minute hour dayofmonth month dayofweek ; ala cron, star is implied
;1=00 * * * * ;run macro 1 on the hour
; EVENTS
[events1976]
; Commands for FOB COS indicator when available
; For this to work you must also add - gpio4 = out,0 - to simpleusb.conf
; Uncomment (remove :wink: on next two lines to activate
;cop,62,GPIO4:1 = c|t|RPT_RXKEYED
;cop,62,GPIO4:0 = c|f|RPT_RXKEYED
[events1999]
; FUNCTIONS
[functions1976]
; disconnect link = *1
1=ilink,1
; monitor link = *2
2=ilink,2
; connect link transceive = *3
3=ilink,3
; remote command = *4
4=ilink,4
; execute macro = *5<macro#>
5=macro,1
; system status
70=ilink,5
; disconnect permanently connected link = *71
71=ilink,11
; connect link permanent monitor = *72
72=ilink,12
; connect link permanent transceive = *73
73=ilink,13
; play full system status
75=ilink,15
; disconnect all links
76=ilink,6
; reconnect previously disconnected links
77=ilink,16
; permanently monitor link – local Monitor only
78=ilink,18
80=status,11 ; ID (local)
;81=status,12 ; Time of Day (local) old method
;Say 12 hour time on node 1
; Add local ZIP before node for weather also
81=cmd,/usr/local/sbin/saytime.pl 1976
; Say 24 hour time on node 1
82=cmd,/usr/local/sbin/say24time.pl 1976
; Autopatch must be configured to work
; Autopatch up
61=autopatchup,context=radio,noct=1,farenddisconnect=1,dialtime=20000,quiet=1
; Autopatch down
0=autopatchdn
; Example Play a Node announcement
; Audio file must be Allstar compliant
;920=localplay,/etc/asterisk/local/some-file
;989=cop,4
980=status,3
99=cop,6 ; PPT on, # = release
; Functions to call utility scripts
; Some of these are commented out.
; For use Remove ‘;’ and change function
; command and node to your choice
; Note that halting the system remotely would require
; a power cycle to recover, use with caution!
A1=cmd,/usr/local/sbin/sayip.sh 1976 ; Say local IP to radio
A3=cmd,/usr/local/sbin/saypublicip.sh 1976 ; Say Public IP to radio
A5=cmd,/usr/local/sbin/sayreg.sh ; Say Registration status
					; Say DNS node lookup
A7=autopatchup,context=saydns,noct=1,farenddisconnect=1,dialtime=15000,quiet=1
A9=cop,55 ; One time parrot
;B1=cmd,/usr/local/sbin/halt.sh 1976 ; Halt the system (linux total shutdown)
;B3=cmd,/usr/local/sbin/reboot.sh 1976 ; Reboot the system
B6=cmd,/usr/local/sbin/astres.sh ; Restart Asterisk
					; Update hamvoip with voice feedback
;C2=cmd,/usr/local/sbin/say-hamvoip-sys-update.sh
; MACROS
; Place command macros here
[macro1976]
;Macro number = command string (each command separated by space) -end with HASH
1=*81 *80# ; play time and voice ID
2=*731977#
; TELEMETRY COURTESY TONE DEFINITIONS
[telemetry1976]
ct1=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct2=|t(660,880,150,2048)
ct3=|t(440,0,150,4096)
ct4=|t(550,0,150,2048)
ct5=|t(660,0,150,2048)
ct6=|t(880,0,150,2048)
ct7=|t(660,440,150,2048)
ct8=|t(700,1100,150,2048) ; 2048 amplitude
remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000);
remotemon=|t(1209,0,50,2048)
cmdmode=|t(900,903,200,2048)
functcomplete=|t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
patchup=rpt/callproceeding
patchdown=rpt/callterminated
; WAIT TIMES
; A section for wait times can be defined for every repeater (node)
[wait-times1976]
telemwait=600
idwait=600
unkeywait=800
calltermwait=2000
; LOCAL NODE ROUTING
; Define local nodes
[nodes]
1976 = radio@127.0.0.1:4573/1976,NONE
1977 = radio@127.0.0.1:4574/1977,NONE
Unless you are talking about a RF connection between the two,
This is not possible without a data connection between the two.
Not necessarily ‘internet’ but network connection.
The software relies on a digital network IAX2 connection.
So you need some network connection between the two.
If you have or can create that,
simply follow this in the wiki for the private node connection between 2 servers.
https://wiki.allstarlink.org/wiki/Private_nodes#Specific_non-local_standard_connections
Yes there will eventually be the exact same configuration at the site with internet. RF link to node 1976. So Node 1976 and 1977 are at the same location. One is on the RF link simplex radio and one on the UHF repeater. So I need 1976 and 77 to connect to each other. I knew that I would have to make up a network be it 192.xxx or 10.xxx. I don’t know the configuration to make those two talk, key at the same time. 1976 hears a signal from the other simplex node up on the mountain, maybe it will be node 1975, then keys 1977, the repeater. Thus a RF link from the two sites.
Well, where does allstar fit into this connection scheme ?
