can andybody built me preconfigured node image so i can just burn and plug in
with m information on my node and so on ?
If you’re familiar with Linux, you can use our live builder:
Once you’re able to simply build an image, you can add your own files to:
config/etc/asterisk
But it’s no small feat to get this going. A lot of setup and tinkering is involved. The instructions on github should get you most of the way there.
Cheers,
Rob
KK9ROB
Neat. How long has that been around?
Rob I looked at what is on GitHub though only on my phone but is this an asterisk or full os installation. Not familiar with the term “live”
George C
Live normally means you run it from the command line and it downloads and installs.
Have you tried the ISO image
Ignore the live part, but that repo is a set of scripts uses Debian Live to generate an ISO or an IMG for Pi.
