Port forwarding node 28177
Cannot receive incoming connections on node 28177. Using Belkin router with port forwarding set to send port 4569 to a static ip of 192.168.2.3 udp Can ping google .com ok and all the other pc’s on the lan. Would you check my node in the registration server.
Jack Bumgarner
ws5d
Looks like it’s working now. It can take a while for a node to download the allstar directory after turning it on. Maybe as long as 10 or 20 minutes.
Tim
:wq
Jack Bumgarner
ws5d
ohnosec.org
Here is how your node appears to everyone else:
28177=radio@75.111.111.87:4569/28177,75.111.111.87
This entry is found in the file ...
/var/lib/asterisk/rpt_extnodes
Just for fun, I would try changing the packet type from "UDP" to "ALL".
I think I have run across this issue before somewhere in the past.
N5ZUA
----- Original Message ----- From: Jwbfre@aol.com
To: app_rpt-users@ohnosec.org
Sent: Tuesday, December 06, 2011 12:45 PM
Subject: [App_rpt-users] Port forwarding node 28177
Cannot receive incoming connections on node 28177. Using Belkin router with port forwarding set to send port 4569 to a static ip of 192.168.2.3 udp Can ping google .com ok and all the other pc's on the lan. Would you check my node in the registration server.
Jack Bumgarner
ws5d
