I can access the supermon dashboard no from anywhere in the internet on port 443, but I noticed two issues:
If I click on the button for the Connection log or any of those buttons that produce a pop up window, those windows come up but blank, also the table where the nodes status is supposed to show IDLE or any of those states, appears empty and with a message " Waiting…" could this be a port forwarding issue? if so which ports should I allow through the firewall?
UPDATE: I tested from within the same network using another PC on port 443 and same result the “Waiting…” message sits there forever so it is not a firewall issue it seems more a configuration issue on a file in the supermon folder, but no idea which one.
Thanks in advance
Alex N2IX
