Port forarding on Mikrotik Router OS
Does anyone use Mikrotik routers with Allstar?
Fiber ISP with Static IP address, not blocking ports. I had it working with a OPNSense router before I updated and created multiple issues so I know the connection works
Router is a RB-450Gx2 with Router OS ver 7.23.3
I have setup the DST-dat for UDP port 4570 (correct port) as plan to move this node to a site where there is another node. Then a firewall rule to forward udp 4570 from WAN interface to accept
Parrot Node 2002 shows node is reachable
Any ideas?
Jerry
I have tons of it behind Mikrotik. Very common in the amateur world.
Make sure that your rule is in the forward chain and that it's specifically permitting the destination NAT:
39    ;;; -----===== ASL Sever 460181 =====-----
      chain=forward action=accept protocol=udp dst-address=172.17.16.136 dst-port=4570 log=no log-prefix=""
For example, in one of my devices I have a dstnat on port 4570 to 172.17.16.136. This is the corresponding filter rule.
There is port mapping on the quick set page or ip firewall NAT... However, if you have wide open ports on your static ip, then why???
I use Ham 44 addresses that are wide open and close what ports I don't use...on my mikrotiks.
This setup tunnels through your router via wireguard and the ISP only sees the tunnel, but no idea what it is....
Setting up Ham44 is very easy on the GL-inet SFT-1200 and you get multiple static ip addresses (/28, /29).
My rules after slight revision
action=accept chain=forward dst-address=192.168.3.62 dst-port=4570
protocol=udp
action=dst-nat chain=dstnat dst-port=4570 protocol=udp to-addresses=
192.168.3.62 to-ports=4570
Now it connects momentarily no audio passes then disconnects
Both of your servers are set to 4570, just FYI.
