Please let me know everyone.
**Please let me know everyone.
I want to get a new node number, but I’m having trouble.
Please give me some advice.
I entered JR2DHR-1 from Prtal ServerSettings AddNewserver ProceedNewserverSetup
and clicked Submit.
I’ve waited 10 days but haven’t received an email.**
It should be automatic and you don’t get an email. What is your portal username?
George,
Your account shows one node.63118
I assume you knew that at this point as it shows as registered.
If not say something more about your issue.
日本語で 書きます
allstarlinkとdv-switchServerを
同時に作動させて
Dmr TGIFの運用をしています
この方式はBLUEDVやdroidstarより音が良く気に入っています。
もう一つ
TGIFを運用したいので
もう一つ Nodeを取得したいのです
今JR2DHRで63118を取得しています
もう一つJR2DHR-1で取得したいのです
It seems under current procedure, since you have one number assignment.
You will need to convert your existing node to NNX,
which basically converts that one node number to 10 node numbers by adding a digit to the tail end.
So, you will want to convert the existing node to NNX and then you will have 9 others to assign.
63118 would become 631180 or what ever last digit you assign.
https://wiki.allstarlink.org/wiki/NNX
