Date: 2010/02/18 Thu AM 08:11:47 PST
To: app_rpt-users@qrvc.com
Subject: [App_rpt-users] please helphello,
i have installed system elastix on machine1 and it is working fine.. i could
add sip peers and sip peers could contact other sip peears thats ok
also i've motorola sx900 radio ( not only one.. i've many motorola radio)
i would like to connect sip peers to motorola sx900 or inverse...
for example motorola sx900 name is radio1
sip peer name is sip1i've softphone and login sip1 on softphone then dial radio1 and connect then
talk.could you help me please how could i do that
U Can
Hello,
You are going to have to explain in more detail the computer system you have, what asterisk version you are running (i.e. is it ACID or Limey, or some custom setup) and what interface card you are using. Also be prepared to attach configuration files rpt.conf, extensions.conf, iax.conf and sip.conf.
If this is a commercial application requiring support it is best handled privately. Please note that commercial support regarding desired system configurations and or code changes is probably not going to be offered free of charge.
Steve
WA6ZFT
reply (146 Bytes)
